Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Apr 07, 2011 10:51 pm
Better in pink.....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Apr 07, 2011 10:55 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 07, 2011 10:57 pm
It would have been funny :lol:
But he has been great helping me, fixing and moding me with my truck
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Thu Apr 07, 2011 11:05 pm
Found an annoying oil leak when I got home, my own fault really, I took the turbo oil return pipe off last weekend to make sure it didnt have any gung left in it following the recent turbo events and decided to re-use the lower gasket due to it looking okay and not wanting to remove the oil filter to improve access.
Seems I'll be replacing the gasket on Saturday now, once I've dropped the oil and removed the filter first. So that'll be a oil/filter change as well. At least, that'll be the last of the leaks tracked down and sorted.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Fri Apr 08, 2011 8:44 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Fri Apr 08, 2011 3:24 pm
finally got the motor to turn over on the starter..
was turning very slowly, but no longer is it seized...new big end bearings required, as number one is worn from lack of oil...having removed the offender, engine can be turned easily by hand (no sparkie plugs) crankshaft looks and feels ok, but will have to find a measuring caliper to check properly...hoping that it's ok, and I can get away without having the crank re-ground...haven't got the time or money this month & the annual is fast approaching..
this truck again fails to defeat me...it will work again..
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Apr 08, 2011 3:36 pm
cleaned the inside, fookin drifty, gave some oil to simo to top his of, and just had a phone call, can you bring your oil and the spare cap, he left his of and drove home, what a tot,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Fri Apr 08, 2011 4:06 pm
put the 2.2 top end back together an fired it up ticks over ok and dont over heat
will wait till the morning an change oil then take for test drive :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Apr 08, 2011 5:25 pm
yesterday i fitted the new Clutch Slave Cylinder (old one was leaking ). then tried bleeding it but no matter what way i did it the pedal just sat on the floor. so i took the master Cylinder off to have a look at it. then took it apart cos the piston was not moving in /out. the big spring inside had snapped. so went to scrappy for a replacement master Cylinder. job done in the end. so for a simple job it took me 6 hours :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by muddy-duck on Fri Apr 08, 2011 6:19 pm
I took advantage of the 24 degree heat to re-paint the horse trailer ready for next weekend so didn't do much to the truck. Still havn't put the roof back on :lol:
I did take out the EGR valve though and tried to clean it-didn't have any carb cleaner and it wasn't too bad but only took 5 mins so will re-do when I get some carb cleaner. Is there anything else I could use instead?
muddy-duck
Vehicle Name: Sherman
Modifications: Comes with added rust ;-)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Apr 08, 2011 7:39 pm
you could use brake cleaner if you have any of that :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Fri Apr 08, 2011 7:51 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by millenaire on Fri Apr 08, 2011 8:19 pm
Today i beat the devil, i removed the vacuum pipe at the back of the cylinder head, trimmed the dozed piece and replaced it. Sore arms some swearing and ingenuity was what it took, but i did it. Removed egr valve again gave it a wipe and replaced, then topped up oil and coolant.
Quite pleased to get it done. :)
I spent a lot of money on booze, birds and fast cars. The rest I just squandered.
millenaire
Vehicle Name: Black Beast of Arrrgggh
Modifications: Fitted Bose sound system from my now scrapped Alfa Romeo, fitted some tasty spot and fog lights. Fixed speedo problem, cleaned egr and sorted vac pipe issues.
Hammerite and Waxoyl underneath, it's got new discs, pads and copper brake pipes all round. watch this space for the next exciting installment lol.
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by glynn969 on Fri Apr 08, 2011 8:34 pm
finally fitted the snorkel :lol:
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Apr 08, 2011 8:38 pm
oooOOOOoooo.... That look WELL NICE, Glynn. :well done: :well done:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Apr 08, 2011 8:52 pm
Split the exhaust at center idea to remove center box, it came apart shame the nuts on back pipe knackered have grind them aff. Dropped the tank got petrol in eye ran like fun into house head in sink full of water......to be continued
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by muddy-duck on Fri Apr 08, 2011 8:54 pm
muddy-duck
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wokkaben on Sat Apr 09, 2011 9:54 am
Discovered a flat tyre. Ace. :evil:
If it bleeds, I can kill it.
Drive a Lawn Rover? I'd rather fight an angry honey badger!
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=46&t=39338 - the Wokkamobile
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=32&t=39340 - comments on the Wokkamobile
wokkaben
Vehicle Name: The Wokkamobile
Modifications: Debadged Grill. Ice Blue Fogs fitted in front grill. Kingpin AT 235/70/16's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lurch 173 on Sat Apr 09, 2011 3:18 pm
put on new shackles & woundup the torsion bars for a 2 in lift, well happy (it still drives in a stright line) time for a cider :drink: :drink:
lurch 173
Vehicle Name: thug
Modifications: 2 in lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bleu boy on Sat Apr 09, 2011 4:00 pm
ma new wheels on and mot for another year eh now have to start on the 2 inch lift shortly :P Image
bleu boy
