Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vauxsqueeks on Mon Mar 21, 2011 12:11 am
Reason: fixed link
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by aikido on Mon Mar 21, 2011 3:10 pm
Four new tyres!
Yokohama Geolanders 260/70/15 Descibed as part worn in the advert, but on inspection still had the rubber "pips" showing Obviously very low miles :) .
Fitted with new valves and balanced all for £120.00 Bargain! :D
Dave
aikido
Registration Year: 1994/M
Modifications: Hey i only just bought it!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Mar 21, 2011 4:29 pm
I took Beasty for a "Quicky" at the local jet wash. Just to get rid of the accumulation of road cr@p and mud around the arches. Nothing special, as she's getting a full valet in a couple of weeks. 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Mon Mar 21, 2011 6:57 pm
yesterday, Sir-D (and I helped a bit) did a few bits and bobs to Stan, including the wheel arch mod that he has posted details about :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hobsey on Mon Mar 21, 2011 7:23 pm
Discovered I may have the early signs of the headgasket going.
Having a sniff test done tomorrow, if it is then its got to go.
I cant afford to keep paying out for the maintenace. First fuel pump, then rear disc and pads with both calipers and now this.
hobsey
Vehicle Name: Fanny
Modifications: Air freshener
HD Trooper rear coils
2" coil spacers
265/75/16 Fedima Frontieras
Recovery shackle
Magnamount Aerial
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Mar 21, 2011 7:26 pm
thats not good hobsey, aint there any members who can give you a hand to change it ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Mar 21, 2011 8:06 pm
Thats not good news Hobsey, I see on the members map you're really close to me. I have a workshop in Virginia Water, fully equipped to help you out if you need.
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Mar 21, 2011 9:16 pm
thats a fogtastic offer ros :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hobsey on Mon Mar 21, 2011 9:32 pm
Thank you very much, I may have to take you up on that offer if I dont get rid of it first.
I will let you know the out come of the test.
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Mar 21, 2011 9:37 pm
No worries, Dont get rid of the fronty mate, its not a hard job and you'll only have a 2 day wait for the head in between a couple of hours to strip it down and put it back together
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Mon Mar 21, 2011 9:51 pm
Traced the annoying rattle to the offside bonnet hinge rivet. Its going to be a nuisance to cure that one. Fillede up with "go juice" and with all the mixed town/country/towing and 4wdlo mountain climbing has achieve over 24mpg. Well pleased.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigun_1977 on Mon Mar 21, 2011 11:26 pm
hi guys
well to day i fix the leaking erg valve but really want to blank it off also degayed the car took off 4 running lights 2 spots some stick on audi crap look leds moved the reverse spot to the fiber glass cover on rear bood glass took off oll rust side steps ....... on a side note i did see a tech help thread on here on how to cut the boot inspection panal out and fit it tidy can an 1 help
bigun_1977
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Mar 21, 2011 11:46 pm
Bigun, If your talking about chopping a hole out the boot to be able to get at the fuel tank stuff then the first thing to do is make a trip to a scrappies to chop the boot floor out of an old 'A' series LWB, you then use this as your in fill panel as the moulding will be correct to fit the moulding of your boot floor. The bit you cut out on your car won't fit, it will just drop through the hole, it needs to overlap the hole by a good 20mm all round so you have enough room for the screws and instant gasket to make a seal.
Cutting it's the easy bit, just don't cut to deep otherwise you will cut lumps out of the fuel tank and hoses. You can see the top of the tank if you look underneath the rear wheel arches, it's not too difficult to slide a piece of ply in there to protect stuff while cutting.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigun_1977 on Mon Mar 21, 2011 11:50 pm
dont really want to cut but i have no fuel gauge so im stumped
bigun_1977
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Mar 22, 2011 12:02 am
why not just drop the tank.
i did nothing today
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Mar 22, 2011 12:08 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Tue Mar 22, 2011 12:12 am
Drinks
For me, the tank had something like 70ltrs of Dieso in it and I just couldnt be bothered with either getting it all out so I could drop it or struggling with a full tank if I did drop it. As it is I can now access it very easily with out dropping the thing. IMHO vaux should have cut the hole when they were made. Would be soooo much easier.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Mar 22, 2011 12:21 am
Gotta say, the first time my trucks get a tank problem, they are gonna get an inspection flap...
Bushwacker did one in his sport, I think he used a paint tin lid as a cover....such a cowboy! I would use a filler tin lid, got loads more of those after rebuilding the 90!
Hinged would be nice, kinda quicker access :lol: :lol: :lol:
Cant remember but doesnt a sport sender unit location get it kinda in the way of the rear seat securing point... :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Tue Mar 22, 2011 12:47 am
Hopefully admin won't curse too much at this thread straying somewhat but a little advice for anyone cutting the floor of their motor - if using a hole cutter (or a drill in many places) measure the depth you are safe to drill/cut to before doing damage, then apply a band of self adhesive insulation tape around the cutting implement be it the cutter or drill at that depth, then when you drill down dont go into the area of your cutter/drill that is taped - in short - a form of depth guage.
Umm, on thread, checked tread depths today (not using a drill!) - might need new tyres later in the year, wonder what to go for?????
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Mar 22, 2011 9:54 am
reattached side steps after sand blast and galvanized, fixed dash problem too and today i am doing the rear diff greese and clean try fit in front wheel bearing
and a wash
ps i had the alloys done too
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Users browsing this forum: Majestic-12 [Bot] and 27 guests
