Frontera Technical Support • View topic - Help again please
Help again please
Re: Help again please by MuddyFairy on Thu Nov 06, 2008 10:33 am
MuddyFairy
Vehicle Name: Mini Monty
Modifications: 2.2 1998 S Reg LWB in dark metallic green, needs engine. RIP
2.4i 1994 M Reg LWB Carabic Blue, Replaced suspension all around. Planned suspension lift, CB, winch etc. When time and money allows. SOLD
Planning on getting a shorty when money allows!
2.0 1998 R reg SWB (Finally!)
Skype Username: Rachael_Edwards1
Re: Help again please by jmc on Fri Nov 07, 2008 10:02 am
I havent taken a steering wheel off but wish I had an adjustable one like yours.I did take one off an Astra and I think it had a single nut in the middle and the wheel needed a bit of a bang to loosen the tightness on the shaft. Do you have a haynes manual? it may show you how to get it off it that.
jmc
Re: Help again please by Rifleman on Fri Nov 07, 2008 10:18 am
The correct way to get a steering whell off is to slacken off the centre nut, but don't remove it. Grab the wheel at the left and right and violently push down on one side while pulling on the other rocking it loose. If you remove the nut completely before doing this, you may lose a few teeth.
Re: Help again please by MuddyFairy on Fri Nov 07, 2008 5:15 pm
MuddyFairy
Re: Help again please by Rifleman on Fri Nov 07, 2008 5:22 pm
Re: Help again please by bobbinsjob on Fri Nov 07, 2008 7:59 pm
Re: Help again please by Rifleman on Fri Nov 07, 2008 9:20 pm
Re: Help again please by Frontycustoms on Sat Nov 08, 2008 3:55 pm
Ok Rachie so far tomorrow we have Me,Dan n Fudster comin over after lunch ok :wink:
Re: Help again please by MuddyFairy on Sat Nov 08, 2008 6:29 pm
MuddyFairy
Re: Right thats it! by andysd1 on Sat Nov 08, 2008 7:07 pm
Re: Help again please by jellybaby on Sun Nov 09, 2008 10:37 am
good luck with the car with the fog team on it will be fine
Re: Help again please by jmc on Sun Nov 09, 2008 3:05 pm
Thinking about your rear springs.I dont think they are an m.o.t. failure if the bushes are worn but mine did fail last year on one front bottom shock absorber bush and both the bottomones at the back so they ought to be checked first and replaced.Each rubber bush has two parts which fit together on the bolt. It may be worth asking fog about coil springs instead of leaf.Hope it goes well today.
jmc
Re: Help again please by MuddyFairy on Sun Nov 09, 2008 3:16 pm
MuddyFairy
Re: Help again please by MuddyFairy on Sun Nov 09, 2008 5:37 pm
Many thanks to Fronty Customs for travelling down and braving the elements to fix my car electrics! Just have the tow bar electrics to sort now as Fronty Customs thinks this is causing my brake light problems.
But thank you so much. He didn't even eat any biscuits! I owe you one mate. You were truly fantastic!!! :P
MuddyFairy
Re: Help again please by Frontycustoms on Sun Nov 09, 2008 6:36 pm
Hey, not a problem. At least u got lights now hey n all the dash works now. Just tryin to find out the wiring on the tow plug, if anyone knows it could be of some help.
When the brakes are pressed the lights work fine..........but, when the side lights are on the near side one goes out. Managed to sort the earths on the rear light clusters but traced a feed to the tow socket n didnt get anythin off it.
Re: Help again please by andysd1 on Sun Nov 09, 2008 6:40 pm
i had a similar problem check bulbs and changed them, also the connectors in the cluster, just bent them a bit more away from each other,
Re: Help again please by Frontycustoms on Sun Nov 09, 2008 6:44 pm
Yeah thought of that but still didnt work Andy :(
Re: Help again please by Frontycustoms on Sun Nov 09, 2008 7:16 pm
WIRING DIAGRAM FOR 12N TYPE 7-PIN Black socket or plug
for vehicle road lights
Colour Terminal Purpose Looking at the Socket towards the plug.
Looking at the Plug towards the socket.
Yellow 1 (L) LH Indicator
Blue 2 (54G) Rear Fog Light (or Aux.)
White 3 (31) Earth
Green 4 (R) RH Indicator
Brown 5 (58R) RH side Light Stop
Red 6 (54) Lights
Black 7 (58L) LH Side Light
Re: Help again please by Drift on Sun Nov 09, 2008 7:17 pm
Will this help?
Re: Help again please by Frontycustoms on Sun Nov 09, 2008 7:19 pm
:lol: :lol: :lol: :lol: Beat ya Ste :lol: :lol: :lol:
