Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Mar 05, 2011 2:09 am
put the beer down and go to bed
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Mar 05, 2011 2:12 am
Okay, just let me then :shock: :sick:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Gazeddy on Sat Mar 05, 2011 10:41 am
got it a set of new boots and full filter service. looking at timing belt next weekend
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by justdan on Sat Mar 05, 2011 10:43 am
oil and filter change .......... rubbed down , filled and sprayed my bonnet .... sanding and filling did a great job i must say ! spraying mmmmmmmmmmmm :oops: :oops: :oops:
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Smithy501 on Sat Mar 05, 2011 10:46 am
at moment im giving my engine bit of a clean make sure everything connect right and at moment flushing water out if rad topping the coolant up basic stuff but it what im doing today
need to do the dash fix on mine later on aswell just fitting it into my drinking schedule then remove bass box out boot and hoover and cast a side for abit im giving it a good valet :P
If life hands you a lemon,,,,, Quickly grab it and throw it at someone!!
Smithy501
Location: Broome Shropshire Between Aston on clun and Craven arms
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Sat Mar 05, 2011 2:45 pm
Went outside, had a look at the truck, thought to bloody cold to do anything plus i'm still waiting on parts.
So went back indoors sat down with a coffee and watched telly :lol: :lol:
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wokkaben on Sat Mar 05, 2011 2:49 pm
look at the sticky regarding quotes
In Facebook fashion, I "like" this!
If it bleeds, I can kill it.
Drive a Lawn Rover? I'd rather fight an angry honey badger!
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=46&t=39338 - the Wokkamobile
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=32&t=39340 - comments on the Wokkamobile
wokkaben
Vehicle Name: The Wokkamobile
Modifications: Debadged Grill. Ice Blue Fogs fitted in front grill. Kingpin AT 235/70/16's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tucker on Sat Mar 05, 2011 3:23 pm
Done a bit of sound deadening last week,a trip to the scrap yard,picked up three under the hood sound deadening mats the cleanest i could find £5.
First job engine bay,using thin cardboard as a tem/plate i cut out the shapes on the existing sound deadening material on the inner bulk head,then cut out the pieces from one of the mats,using spray on glue i've doubled the thickness of the sound deadening,next over the wheel arches including under the air box.
Inside the cabin,passenger and drivers footwell,right under dash it was bare metal on mine,cut to shape and glued on,making sure the hot air outlet was'nt obstructed,and all three pedals could be depressed.
Next,under the back seat using one of the mats cut to fit no glue the seat holds it in place.
In the boot,removed the plastic trim from around the wheel arches cut to fit on the bare metal then glued on,at the same time i cut out a piece of thick foam back carpet i had in the garage and put it under the boot carpet then replaced all the trim.
The back door,took off the plastic covering and with my last mat,i cut to shape on the metal side and glued on i was going to do all four doors but i ran out of material,plus there was the electrics to consider.a job for the future perhaps!!
Did it work,...sort of,...at tickover and low speed there's an inprovment,at a higher speed..the jury's still out :wink: .
Tucker...2.2 DTI Irmscher.
tucker
Vehicle Name: costaplenty
Modifications: Irmscher pack, Window air deflectors,sound deading in all the doors,& under the bonnet.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fallguy on Sat Mar 05, 2011 5:22 pm
re painted towbar with hammerite spray , removed genuine vaux sidesteps as the top plastic bits were coming away from the frame and one of thems rusted through, pro's = i can now crawl below the truck easier, can wax polish the sills easier. cons = the sidesteps kept the side of the wagon cleaner, you can see more 'bits' hanging below - it looks kinda naked. :|
99 lwb 2.2 dti - sold, now 03 2.2dti lwb olympus
Fallguy
Vehicle Name: olympus
Modifications: monroe 4x4 adventure shocks, m.a.d. rear inner towing coils gaining a 30mm lift, front torsion lift, tints, optima redtop, jvc ice, thule bars, rectangular spotties on soft a bar, factory fogs replaced with microline lights, raised breathers, towing an 06 abbey gts vogue 517.
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sat Mar 05, 2011 6:50 pm
I didnt do anything to my Fronty today but I did this job to my caravan though. :rotfl: :rotfl: :rotfl:
Swapped the front marker lights from the square ones:-
For these,flush mount LED side marker lights:-
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Mar 05, 2011 6:52 pm
Got me a virtually brand new rad for 25 sheets. Very happy with that :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sat Mar 05, 2011 7:06 pm
LOOK AT THE STICKY REGARDING QUOTES
Aye, I would be too.
:well done: :well done: :well done:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MARKSHOG on Sat Mar 05, 2011 7:38 pm
Gave her a good wash and cleaned out the inside :drink:
MARKSHOG
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wokkaben on Sat Mar 05, 2011 9:03 pm
Put a sticker on the back window...."Support Our Lifeboats" One of 3 charities I support.
Got frustrated with the O/S balljoint squeak.
Filled it to the gunwales with rubbish to take to the tip, I love having a LWB!
wokkaben
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sat Mar 05, 2011 9:23 pm
used it to do two homers servicing
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by th4neuk on Sat Mar 05, 2011 9:26 pm
Fitted my K&N panel filter.
Awesome sound through the snorkel now!!
Alan
Alan
th4neuk
Sidesteps
Rear privacy glass stuff
Tweaked torsion bar
BFG AT's
Extra reversing lights
Wish List
Rear Spring +2"
+2" Shocks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Mar 05, 2011 9:58 pm
Today i bled the clutch on Chrissy's truck co's it was playin up. The crap that came out was awful so i thought i would give mine ago, that was the same. Looked more like black paint than oil. Also on inspection Chrissy's needs a new rear crankcase oil seal. Mine's going to need a new clutch no ajustment left on it and it virtualy on the floor to disengage. Oh well 2 more gearbox's to take off, getting used to them now!!! :( :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Sat Mar 05, 2011 10:25 pm
changed 10 wheels, with a bit of help, and waved Pindy goodbye :wave:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Mar 06, 2011 2:37 am
Ten wheels on what?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Mar 06, 2011 3:11 am
this is how drinks
my day trip, i went to meet pindy,
started out great, galaxy passed its mot, back in storage for 12 months after today,
shot home picked up jack and stand, got about three miles, and turned back, doh, for got the bowel,
of i go again only to get stuck on the runcorn bridge for just over 1 hour, bloody painters,
finally got moving,
a few pics on route,
arrived, and got spotted
started to change wheels, well, i done the jacking, and CC, removed the nuts and wheels
CC, had dirty hands,
on my home, i ran in to some of drifty's lose woman
my only passengers,
home,
and the trust stead that got me there and back
oh she has a new name,
STING
