Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Feb 25, 2011 9:14 pm
Bought a new (well old actually) Frontera Sport pickup.
Didn't get it home until 5pm, but it's been cleaned since these pics - levels checked and 2 litres of oil chucked in the rear diff.
Pics here http://s54.photobucket.com/albums/g85/b ... a%20Sport/
EDIT: Link fixed.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Feb 25, 2011 9:18 pm
very nice mate looks good ,is that the one that was for sale on here ?
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Feb 25, 2011 9:44 pm
Yes mate, it was frontycustoms truck.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Feb 25, 2011 9:50 pm
Si. That link you put up has no pics of ya new truck. It points to the thread for recovery points. :butt:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wokkaben on Fri Feb 25, 2011 9:54 pm
Took drivers door apart to cure a rattle, found at least 1/2kg of shattered window glass in the bottom, hoovered out and removed several large sections of skin whilst doing so.
Found door lock rod rubbing against door panel, glued in some foam, rubbing stopped.
"Plumbed" in wire to fit switch for spots, will connect tomorrow or Sunday
All removed door parts were scrubbed clean in hot soapy water
Central locking adjusted to work properly
Attempted to mount spare wheel on roof, without a roof rack, this was deemed a crappy idea by me, and thus will wait until roof rack is made. Tyre will now reside in the boot for now
Whilst fitting in switch wire, found a circuit board wrapped in brown parcel tape, with several yards of wires poking out, also attached with electrical tape were two black boxes of indetermite origin, and one lone grey wire with "ariel do not cut" written on it. I suspect it is a basterdised/homemade/shoddy repaired immobilizer - pics to follow.
A busy afternoon.
If it bleeds, I can kill it.
Drive a Lawn Rover? I'd rather fight an angry honey badger!
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=46&t=39338 - the Wokkamobile
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=32&t=39340 - comments on the Wokkamobile
wokkaben
Vehicle Name: The Wokkamobile
Modifications: Debadged Grill. Ice Blue Fogs fitted in front grill. Kingpin AT 235/70/16's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Feb 25, 2011 10:04 pm
:shock: eek
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Feb 25, 2011 10:27 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Feb 25, 2011 10:58 pm
Yeah if i can pick up a roof cheaply I may well convert it back. It's already causing arguments with the kids :|
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Fri Feb 25, 2011 11:06 pm
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Feb 25, 2011 11:08 pm
The only reason is that all my daughters love greenlaning so there is bound to be a day when all three want to come at the same time. :|
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Fri Feb 25, 2011 11:10 pm
I see, are you going to sell your dti on then
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Fri Feb 25, 2011 11:17 pm
Replaced all rubber seals on my leaking front brake caliper. Hope this cures my loss of brake fluid :cry:
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Feb 25, 2011 11:21 pm
rospicer - possibly
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Fri Feb 25, 2011 11:46 pm
It rained, as forecast, but no drips appeared around the sunroof seal - this may be progress. On the down side, have heard a scraping noise from the back of the car when either accelerating or turning - intermittent at the moment and have not got a clue what is causing it but its definitely in the mechanicals as it is more apparent when the windows open. Hmmm.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 26, 2011 12:18 am
Pop the question in the techi area Dave, should get some ideas posted there 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sat Feb 26, 2011 12:20 am
taxed both fronty's and then decided to sell the sports
had it nearly 3 yrs but not used it hardly in last year
i lent a mate it for 2 months while he fixed his
and the son used it in the bad weather
and i used it one day a week just to keep it moving
seemed a waste to leave it parked up most of the time
so im down to just the one now :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Feb 26, 2011 12:27 am
The bargain Cornish 2.2 eh Smiffy :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dave1966 on Sat Feb 26, 2011 12:42 am
One light not working. :(
Managed to get the light sorted that wasnt working and it was a bad connection. :lol:
R.I.P Sable!(2005 to 2013)
dave1966
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sat Feb 26, 2011 12:46 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Feb 26, 2011 7:31 am
