Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Feb 20, 2011 10:06 pm
wow, in the first picture it looks like yours has given birth
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Lee_R on Sun Feb 20, 2011 10:28 pm
New battery and a 4 new glow plugs...starts lov-erly now :D
Also fixed a rather worrying fuel leak coming from the rubber cap on the top of the front injector which was spraying diesel all down the side of the block and over the top of the filter :shock:
Lee_R
Registration Year: 1992/K
New rear leaf springs
Wheels refurbished
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Feb 21, 2011 12:29 am
fitted my url sticker's from tom plus bash plate from krusher
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Feb 21, 2011 11:19 am
Yesterday actually. I took Beasty up to Drumclog for a spot of off roading. She performed AMAZINGLY well off road. All the way to the end...when I got stuck in the mud run. See ling below for the pics and vids...
viewtopic.php?f=37&t=41045
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Mon Feb 21, 2011 6:30 pm
I thought I would get my manual hubs fitted today (cheers Colley), went out got the N/S off and the new one on. Then all of a sudden
it went really dark so now I have one manual hub and one auto. Hopefully I will have a short day at work tomoz and I can do the other side. :D :D
Also got my boy Sam out to earn some pocket money by cleaning and vacuuming all the mud and leaves out from the picnic last week......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Feb 21, 2011 7:13 pm
We can finish them Saturday if needed Kel :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Mon Feb 21, 2011 7:35 pm
Cheers Ste..... :wink: :party:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Feb 21, 2011 9:53 pm
Did my N/S CV boot. Was still quite a lot of grease in the joint and not too much dirt so hopefully all's still well in the joint :D
SHE MUST GET BIGGER BOOTS
rospicer
Vehicle Name: COMING SOON
Skype Username: spicechop
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Feb 21, 2011 9:58 pm
Something wrong here I think..... :? Is that pic the right size? I've set it to small in photobucket but still comes out huge on the forum??
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Feb 21, 2011 10:01 pm
looks OK to me matey :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Mon Feb 21, 2011 10:05 pm
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by roiphil on Tue Feb 22, 2011 11:09 am
New thermostat, rad flush and i have decent heat inside for the first time since i have owned the jeep :party: plus the temp gauge moves to half way (hope taht right) never seen it that high before
In Southern Ireland
94 Frontera Sport 2.0I
I can see the mountains so its going to rain !
i cant see the mountains so its raining !
roiphil
Registration Year: 1994/M
Vehicle Name: Jeep
Modifications: Southern Ireland
Southern Ireland number plates
Immobiliser immobilised as it was a pain in the 4rse
Converted to commercial
Wrap around bullbar, driving lights and fog lights
Roof Bar Lights
(come at me with your full beams boy racers and you get an eyefull of 10 lights)
Rear light guards bumper and body ones
LWB Rear Body Lights
Rock Sliders
(I like my allround protection)
255/75 R15 Kumho
Pajero Seats
38mm Wheel Spacers
2 inch suspension lift
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Feb 22, 2011 12:21 pm
fitting new back box
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by plumjam on Tue Feb 22, 2011 5:29 pm
done a bit today!!
removed the middle sump gaurd and cleaned off and given a couple of coats of fresh paint,
been to get some new bolts to replace them silly torx head things i removed,
got six galved bolts with 17mm heads for £2.50 thought that was good,
changed the air filter & oil filter and oil while waiting for paint to dry,
got to say the oil filter on the 2.8 is a pain to get at for removal :evil: :evil: :evil:
still all done with fresh oil and a nice painted sump gaurd re-fitted...
got to find another job to do now :(
if its not broke just let me fix it for ya!!!
plumjam
Vehicle Name: The evil twin
Modifications: 2.8td totally standard as yet..
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rospicer on Tue Feb 22, 2011 7:04 pm
Removed the Intake manifold which revealed badly cracked gaskets. :evil: Obviously the reason for some eratic idleing and over revving through all gears. So now needing to sort some replacements asap. After that decided to get a little dirty and wire brush the chassis and suspension, gave it a good coat of KURUST and sprayed it with Hammerite. So starting to look like new underneath :D
rospicer
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Tue Feb 22, 2011 9:35 pm
Almost ran out of diesel. Must have been running on fumes on the way to the garage. :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Tue Feb 22, 2011 9:52 pm
Found my rear tyre almost flat, so I examined it and found a screw wedged between the lugs. Pulled it out, let air out and put in a piece of tyresealer rubbercoated string. Took me 20 minutes including cleaning up. Nice :-)
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Tue Feb 22, 2011 10:46 pm
Steam cleaned boot carpet then gave the whole car a damn good clean. 4 hours later ..... :|
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Feb 23, 2011 2:22 pm
taxed digger thats him on he road
went and fixed mates hydraulic ramps
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Feb 23, 2011 6:57 pm
just got a cracking mobile valet of my mate Chris
see here full mobile valet
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
