Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Sun Jan 23, 2011 9:18 pm
Last edited by john (smifffy) on Mon Jan 24, 2011 10:43 am, edited 1 time in total.
Reason: removed images
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sun Jan 23, 2011 9:27 pm
Last edited by john (smifffy) on Mon Jan 24, 2011 10:44 am, edited 1 time in total.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Sun Jan 23, 2011 9:56 pm
We need a "how to do it".
Want some.
Oh yes.
By the way ...Tow started a green oval with one of those BMW things where an engine should be.
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jan 24, 2011 12:17 am
Set to on two more of the rims. Should have 4 ready for tyres next weekend.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tom on Mon Jan 24, 2011 1:17 am
tom
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Mon Jan 24, 2011 8:13 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Mon Jan 24, 2011 9:12 am
Yesterday... broke down on a main road. Engine cut out at 50mph, coasted to the side, hazards on, traffic stacking up behind.
All the ignition lights were on, it would crank but would not fire. Popped bonnedt, disconnected and reconnected the MAF and Crank Position Sensor electrical connections, tried the key and it fired up - been fine ever since.
Looks like I'll gace to tweak the connectors to ensure a cood electrical connection - they're probably a bit worn.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Jan 24, 2011 1:39 pm
I greased all the hinges, wiper mechanisms and the bonnet catch. Topped up the break & clutch fluid, and the PAS fluid...steering doesn't groan now. :lol:
Also adjusted the steering, and gave the interior a quick wipe over with some cleaning wipes. :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Mon Jan 24, 2011 4:23 pm
Fixed the fault i had with under bonnet spots, (bad earth on truck and a loose connection at one of the spots),
Replaced a worn wheel bearing (noticed brake pads are nearly shot so baught new ones for another day),
Washed all the crappy salt off the truck.
:D
PixelMonkey
Vehicle Name: Mini Monsta!
Modifications: Debadged
Mud Guards Removed
Spare Wheel Carrier Removed
Rear Seat Removed
Rear Bumpers Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Black Suede Headlining
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
Red L.E.D. Dash Conversion
Blue L.E.D. Interior Lights
+2" Coils
+2" ES9000 Pro Comp Shocks
2" Body Lift
Much much more to come.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jan 24, 2011 7:41 pm
Finally got my hand throttle working again. Thought it was disconnected or broken, Turned out to be clunged with gack. Liberal useage of WD40 and hey presto. Now I can set the idle revs anywhere between 650-3000 rpm.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Jan 24, 2011 8:07 pm
I know it Jon :wink:
Well I just tax her online for another year...ouch :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Tue Jan 25, 2011 10:29 am
Hi All
Fitted a new UJ to the rear of the rear prop, took about 45 minutes after I got the prop off, no more squeaks from that area.
Was quotes various prices including £52.86 from one national parts supplier, my local high street supplier fitted me up with a Quinton Hasel unit part number QL16103 for £18.00. came with clips and fits a treat, down side is that it's a sealed for lift version (no grease nipple).
Laters
Stuart :D
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Tue Jan 25, 2011 2:27 pm
Tom, those LED lamps you have fitted to your Frontera, are they self adhesive or have you had to do some drilling? Cheers. David.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jan 25, 2011 4:06 pm
Ordered some new metal tyre valves for the new rims.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fenwoman on Tue Jan 25, 2011 4:29 pm
I kicked her and swore at her, then decided to sell her, so came on here and posted an advert'. Enough is enough already!!
fenwoman
Vehicle Name: Fenella
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Jan 25, 2011 4:34 pm
Took the Picasso for an MOT and did an oil and filter change and thats about it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Big Dav on Wed Jan 26, 2011 7:34 pm
Painted another coat on the new plate that was welded to the drivers side sill. Dug out an old pair of headlamp protectors which, of a fashion, fit the Fronty and fitted them. With all the pot holes and associated gravel don't want to risk a cracked headlamp lens.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Wed Jan 26, 2011 8:52 pm
Put another new dent in Tessie today :lol:
Alternator belt snapped on me which meant no brakes (who's idea was it to fit the vacuum pump on the alternator?) :shock:
temp went up into the red and oil pressure went south :lol:
Will have a look at the true extent of damage tomorrow in day light
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Jan 26, 2011 10:34 pm
I put a few stickers on Beasty. All the same design. One on each lower corner of the rear window and one on the bonnet just above the Vauxhall badge.
http://www.facebook.com/photo.php?pid=2 ... 1371455155
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Jan 26, 2011 11:43 pm
bought a 3.2
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
