Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jan 19, 2011 6:27 pm
Fitted the CB at long last.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Wed Jan 19, 2011 6:36 pm
Installed the turbo boost gauge.....see here viewtopic.php?f=9&t=39770
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jan 19, 2011 6:58 pm
that looks a knee basher boxclev
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jan 19, 2011 7:12 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jan 19, 2011 7:17 pm
why not put it in the center console
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Jan 19, 2011 7:17 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jan 19, 2011 7:19 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jan 19, 2011 7:22 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Jan 19, 2011 7:23 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Jan 19, 2011 7:28 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Jan 19, 2011 7:31 pm
looks good mate think i will do the same thanks for the idea :D[/quote]
It works (and fits) perfectly for me, but I do accept that depending on your height/size seat position etc it may not be ideal for everyone.[/quote]
i ran it of battery on Betsy always forgot to switch it off lol
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jan 19, 2011 7:32 pm
If it works for you thats what matters
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Jan 19, 2011 8:10 pm
Nice place Ian !!!! Just wait till you flood it like i did on mine, thats why i moved it to ontop of the dash!
And trust me you will!!!!! :mrgreen: :mrgreen: :mrgreen:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Wed Jan 19, 2011 9:23 pm
mine is ontop of the dash just behind the steering wheel. and i have a permanent live that has it's own switch from the battery
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed Jan 19, 2011 11:02 pm
Removed tank.
made one new tank strap..
found one under heat shield is also shot..
ripped bolts through heat shield while undoing other tank strap..
removed loads of mud from Wales out of guard..
re-painted inside of tank guard..
cleaned petrol tank..
got cold..so gave up..second half will be tomorrow..
plus side no sheared bolts..(couple of split pipes and destroyed 13 year old clips..but hey ho, what do you expect)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Jan 20, 2011 10:36 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Fri Jan 21, 2011 12:06 am
Nearly killed some suicidal idiot in a small 2 door rusty hatchback on the mainroad going through Lyneham.
Parking space out side of the Tesco (on the main road) I was on the other side of the road, did the mirror, signal, mirror, manoeuvre bit and crossed over to go into the space. Meantime suicide jockey in the rust heap decides to take off like a loon... no looksee, no signals and no mirror action, the only reason he didnt get tyre tracks across the roof was me stomping on the brakes.
It's not as if the frontie is'nt obvious. It's big enough to have filled the mirror if it had only looked ffs, the only thing it saw when finally looking out the window was the frontera and I always, out of habit drive with the lights on, day or night (too used to Volvo's and the daytime running light).
Next time I'm just gonna park on top and forget the brakes. Still fuming lol.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Jan 21, 2011 4:36 am
dazz im 6ft 4" & 18 stone with size 12 feet , i know your much the same & seeing as theres not as much room behind the wheel in a b as there is in an a id say stick it on the passenger side mate :wink:[/quote]
good point mate think i will do that cheers
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Jan 21, 2011 12:48 pm
I fitted some LED DRL's. They're wired up to fuse 7 in the engine bay (interior fans) and go on and off when the engine does.
SEE HERE
I got them off eBay, CLICK HERE
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Fatbaz on Fri Jan 21, 2011 1:03 pm
Hi All
Broke it :( ............Had an occasional squeak for a day or two, have had a look several time, checked wheel bearings greased shafts checked brakes and calipers oil levels etc and still nothing. Week ago, while driving I thought I could feel a shuddering, haven't driven it since (been to hospital and had a small op on a knee). Today I drove to the post box and the squeal was constant under throttle, running light throttle all was OK. Had a look when I got back and low and behold the rear prop rear UJ has decided to retire, there's a fair bit of play in one of the cups (must have got some serious cr*p in it while laning over Christmas though I have washed and greased it since).
So I'd better get a new UJ, anybody got any ideas where from and how much roughly (mail order would be good)? Had a look on Ebay but didn't see any for an A series 2.8 sport or a Frontera at all, any ideas what else might fit? Changing it's not a problem, I got a spanner or two!!
Laters
Stuart :?
Fatbaz
Hankook RT03 285/75R16
50mm body lift
