Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Mon Jan 17, 2011 5:46 pm
These arrived today so i fitted my old 6x9's that were sitting in the garage.
http://cgi.ebay.co.uk/x-2-6-X-9-BOX-ENC ... 2eb05b44c0
:D :D
PixelMonkey
Vehicle Name: Mini Monsta!
Modifications: Debadged
Mud Guards Removed
Spare Wheel Carrier Removed
Rear Seat Removed
Rear Bumpers Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Black Suede Headlining
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
Red L.E.D. Dash Conversion
Blue L.E.D. Interior Lights
+2" Coils
+2" ES9000 Pro Comp Shocks
2" Body Lift
Much much more to come.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Jan 17, 2011 6:01 pm
I decided to remove the centre console looking for a live I could tap into when my CB arrives. Wasn't expecting to find a leak though :roll:
It has run through underneath the rear carpets which is why I hadn't spotted it , but it would explain why the windows were always misty :?
Needed a quick fix so a 2 pence piece and some pipe sealant came to the rescue :D
Then fitted something I've had for a while but never get around to fitting. A FOG sticker :wink:
Also removed all electrical connectors from the MAP/MAF/Diesel Pump/Vac pumps and ECU relay and sprayed with contact spray, blew them out with the compressor then sprayed with silicone spray.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Jan 17, 2011 6:43 pm
i used the cigarette lighter for a live
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Mon Jan 17, 2011 6:55 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fudge on Mon Jan 17, 2011 8:41 pm
and the pic's from my lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Jan 17, 2011 9:16 pm
reconnected the battery after a good charge & tested the arches for clearance from lock to lock & its rub free HOORAH :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Mon Jan 17, 2011 10:26 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Mon Jan 17, 2011 10:33 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Jan 17, 2011 10:49 pm
I removed the spare wheel and carrier from the back on The Beast. I think she looks SOOO much better now....
BEFORE.....
AFTER.....
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by snapper on Mon Jan 17, 2011 11:29 pm
Sunday finally decided to do something about the grot on the front of the bonnet, took the angle grinder with wire brush attachment to it (RAMS in place and with the correct ppe) and got the rot out, 15 mins worth of fillering later left it to set while sorting the 12v socket on the dash (fag lighter socket to you smokers).
Not only was it loose in the dash, the positive connection was a bit fryed as well, so stripped it down, straightened it all out, cleaned it all up and re-assembled. Now re-fitted and working fine (those cheap leccy heater/fans are pants.... it did all the damage).
By now the filler had dried out and I was able to get the sander going, all smoothed out, bonnet masked up and the front sprayed up with some matt black. Not the worlds smartest job but hey ho, looks far better than it did.
And yes, one day I will sort the midget out!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Jan 18, 2011 12:09 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Jan 18, 2011 1:50 am
Nothing on the 2.8
Freelander ABS/HDC/TC warning lights are still on, can't get an MOT till they are fixed and have now run of of idea's. Beginning to wish I had never bothered getting one :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Jan 18, 2011 2:07 am
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by PixelMonkey on Tue Jan 18, 2011 9:09 am
PixelMonkey
Mud Guards Removed
Rear Seat Removed
Tinted Windows
Blacked Out Sunroof
Bucket Seats
Custom Dials
Dash Dress up kit
K&N Induction kit
HID Lights
PipeWerx Exhaust
Roof Spots
Under Bumper Spots
Twin Tone Horns
Ecotek CB-26P
+2" Coils
2" Body Lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Jan 18, 2011 11:16 am
drive down a set of stairs then see if they move .
where did you get your shocks from an how much?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Tue Jan 18, 2011 9:53 pm
I fixed my drivers seat (replaced the bolts on the rear mountings). I also fixed the bonnet. Now I can open it without assistance. ;) Who's a good boy then :?:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by wokkaben on Wed Jan 19, 2011 5:08 pm
Gave the outside a wash (i can see out of te windows now!) and hoovered about 4lbs of dirt out of the inside. Started noting a few jobs for the warmer weather.
If it bleeds, I can kill it.
Drive a Lawn Rover? I'd rather fight an angry honey badger!
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=46&t=39338 - the Wokkamobile
http://www.fronteraowners.co.uk/forums/viewtopic.php?f=32&t=39340 - comments on the Wokkamobile
wokkaben
Vehicle Name: The Wokkamobile
Modifications: Debadged Grill. Ice Blue Fogs fitted in front grill. Kingpin AT 235/70/16's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Wed Jan 19, 2011 5:13 pm
I replaced the front interior light on Beasty, with the one out of Chugga. I also put some rear headrests in Beasty. They're black instead of grey so don't technically match, but with the privacy glass on the rear, you can't really tell.
EDIT...pic of rear seats.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Jan 19, 2011 5:21 pm
I got myself roped into fitting a gearbox and transfer box to a V8 engine and offering it up to a truck, think its a LR forgot to ask :oops: :lol:
Oh well a trip to St Helens anyway, I will take pictures :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Wed Jan 19, 2011 6:26 pm
Goy all the jobs done on Angelina and got her thru her test :dance: :dance: :dance:
Rear anti-roll bar poly bushes
New snail Horns
New stereo
New dixie horns 8) 8)
