Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Dec 29, 2010 6:56 pm
The seal may be okay, if the split is outside as if I remember correctly they are double skinned :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Wed Dec 29, 2010 7:12 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by michael1234 on Wed Dec 29, 2010 7:14 pm
michael1234
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Dec 30, 2010 10:43 pm
Was getting annoyed that whenever I turned right the towbar electrics warning buzzer would beep. It's been like that for 2 weeks , so I finally decided to have a look as I was starting to stop indicating when I was turning right as it annoyed me so much :lol:
. No idea how I did it but the towbar electric socket was rammed with mud and water (even though the flap was tight shut) which was obviously causing the problem. Filled it with WD and blew it out with the air line. No more beeping :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Dec 30, 2010 10:49 pm
Took my baby into the garage to get the brakes looked at. Found out rear pads were well worn so looks like gonna have them renewed. He hopefully will cure the need to "pump" the brakes to get them to work.
See here for my problem.... viewtopic.php?f=23&t=39448
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Dec 30, 2010 10:57 pm
Pumping the brakes sounds more like air in the system mate, not brake pads.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Dec 30, 2010 11:08 pm
Yeah I know. That what he said...but they need done anyway. They're WELL low.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Dec 30, 2010 11:10 pm
Nothing quite like the sound of metal grating on metal :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Thu Dec 30, 2010 11:19 pm
lol. Not quite. Good job or I'd be needing to replace the discs too. :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Dec 31, 2010 9:15 am
was stripping betsy again thu
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Dec 31, 2010 8:42 pm
took her out for a 20 mile run to keep her up & running as shes been sitting on the drive for a week or so since the snows been gone
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sat Jan 01, 2011 11:19 am
Washed and polished looks nice and shiny :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Sat Jan 01, 2011 6:40 pm
took the cylinder head off the fronty got to get it skimmed now. all because the frontera 2.2 love's new head gasket's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jan 01, 2011 6:56 pm
I fitted a new thermostat in the 2.8, I used a thermostat meant for the 3.1 Trooper rated at 85d Quinton Hazel 411, the engine heats up a lot faster, in fact the engine actually heats up now, where as before it would be lucky to touch the first white mark, it now sits nicely at just below the second white mark.
I am getting some actual heat out of the heaters now but IT still needs bleeding to bring it up a bit. :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sat Jan 01, 2011 6:59 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jan 01, 2011 7:06 pm
Why thank you James :D
Less than five minutes to do and I wait till the mild weather to do it :oh yer: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by neal on Sat Jan 01, 2011 7:07 pm
gave it a wash looks better now
neal
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Sat Jan 01, 2011 7:14 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Jan 02, 2011 11:50 pm
Prepped the 2.8 ready for a laning trip tomorrow, been ages so really looking forward to getting out
Yesterday I washed out my new (to me) motor and gave it the once over to see what jobs needed doing, not sure if I should mention what I got but it has a green badge on it :oops: :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Jan 03, 2011 12:10 am
A Skoda Chris :shock: :lol: :lol:
I bounced off a couple of trees at JP's farm on a shooting day :lol:
viewtopic.php?f=45&t=39621
