Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Wed Apr 01, 2009 8:12 pm
well after a day fitting geaboxes with erko and post finder i managed to get home and fit the ball joint and new gaiter and re adjust the bearing on the pass side on the dirty diesel :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Rich on Wed Apr 01, 2009 8:49 pm
well done mate you will sleep tonight after all that hard work
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Wed Apr 01, 2009 8:52 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Rich on Wed Apr 01, 2009 9:03 pm
is that why you were being nice to the misses on the phone :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by JueOmega on Wed Apr 01, 2009 9:08 pm
After all my grief with the engine on the 2.5 tractor, I took it for it's dreaded MOT, having not had the fronty long I had no real idea if there was anything likely to cause a failure. "IT PASSED" with a couple of advises so now, it's INSURED, MOT'D and TAXED, all ready for the meet on Sunday
JueOmega
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Rich on Wed Apr 01, 2009 9:25 pm
:D :D :D :D well done mate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Apr 01, 2009 9:27 pm
Made up some brackets to mount the truckman top properly on the chevy, repaired the tailgate locking rods and sourced a rear seal for the tailgate (landcruiser door rubber) as it was missing and hence the tailgate rattled.
Removed the chequer plate running boards as they are pointless, not strong enough to stand on and a pain to clean. and would get ripped of on something sooner or later.
These will be replaced by a set of jackable rocksliders that I will make shortly and weld directly to the chassis. (these might also be a mouting point for the external cage which is looking more likely :lol: :lol: )
Truck looks much taller with the running boards off :dance: :dance:
Measured up for the roof rack and started designing it...but will maybe do differently and incorporate into external cage,dunno yet...
Dug out a pair of lwb wings with arch extensions which will replace the dented chevy wings unless I come up with a o/s sport wing first as have a good sport n/s wing.
Dug out a sport bumper and lubed up all the bolts so I can get the end caps off another day.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Apr 01, 2009 10:50 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Wed Apr 01, 2009 10:55 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Wed Apr 01, 2009 11:12 pm
Adjusted Hand brake then dug out my New Cap for the Eezibleed so far so good,fitted it on the reservoir :D
Found a handy place for the bottle
let the spare wheel down to the 20 psi working pressure as Gunsons recommend,connected the air to the bottle and
It is amazing how quick 1/2 litre blows out at that feeble pressure. :(
So any body wanting to use this system let the spare down to 5 psi & pull the rubber strap twice as tight as you are comfortable with :roll:
Bleed through whole brake system & clutch,then spent the remainder of the day washing the drive :evil: :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frontycustoms on Wed Apr 01, 2009 11:18 pm
Finally fitted my switch pod in & that was it for today.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by country_Est on Wed Apr 01, 2009 11:33 pm
Not today but on Sat I did this
Went out with these
did a bit of this
and
Not my vids but from the bloke behind me
http://www.youtube.com/watch?v=3MAPbc5mr28
http://www.youtube.com/watch?v=b6HrHaaYJzY
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Apr 02, 2009 12:31 am
Not to my truck by CheekyChicks... Changed a rear wheel bearing.
I called Weave a few days ago and asked him about The Bearinator, A friend, top bloke that he is went and got it from him as he had a few bits to do that way anyway and I collected it from A friend last Saturday. Well the bearing arrived tuesday and I decided I wanted a whole day set aside for it so started it today (Wed).
After me telling my dad how the Bearinator was specifically design for Frontera wheel bearings he took an interest and wanted to see how it worked.
I took all the gubbins off, caliper, disc, brake shoes etc and attached the monster slide hammer to the hub.
I thought I would take a little practice swing with it first just to get a feel for the slide action and imagine my surprise when the halfshaft came straight out and flew between my legs following the hammer.
Can I just say how DISAPPOINTED I was! I was expecting the veins in my temples to be popping out and beads of sweat to be running down my forehead and making my shirt stick to my back.
In all honesty though getting the old bearing off the halfshaft more then made up for the lack of hammer action and getting the new one on was a tedious process involving lots of tapping with a lump hammer to get the bearing and collar on properly.
All in all it still took a good few hours, what with tea stops and cigarettes and chatting to cheekychick and wandering into town for grinding discs and general faffing around. Not something I would like to do again in a hurry but all in all not as bad as I thought it was going to be.
Thanks very much Weave mate and A friend for FOG expressing it.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Thu Apr 02, 2009 2:40 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Thu Apr 02, 2009 4:16 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Thu Apr 02, 2009 8:00 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Thu Apr 02, 2009 9:01 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Thu Apr 02, 2009 9:13 am
Everybody seems to be missing a trick here......... The Bearinator is tubular :roll: :idea: why not put the new bearing on the shaft & tap it parallel,then put The Bearinator on the shaft upside down & use it as a DROP HAMMER,the weight of the slide will save an awful lot of your energy :wink:
Also you are both very welcome :dance: although it is a real strain sitting over Dave`s drinking tea & shooting the breeze :wink: :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Adam on Thu Apr 02, 2009 9:24 am
completed the extra wireing for all the lights and removed the old vauxhall badge on the grill and fitted a old style vauxhall name plate, i think it looks a lot better will post a pick of it soon so you can all take the p+ss :wink: :wink:
Adam
Vehicle Name: Mini-Monty
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Thu Apr 02, 2009 9:26 am
I think that the tube needs to be a bit wider, we did think of that, and thought it might be a good idea for mk2 :D that and there are welds on that end from the Alex/Dave improv when they had to use it to get a bearing out that had stayed attached to the car :shock: .
But hey, it is all done now :mrgreen: fingers crossed he doesn't need anything else for his MOT
Glad it gave you a reason for more tea drinking A friend :wink: :wink:
