Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Sun Nov 21, 2010 8:00 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sun Nov 21, 2010 9:20 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Sun Nov 21, 2010 9:53 pm
Drove around some fields and thought how nice it is to have a bolted flywheel and a clutch that works. :dance:
Let it snow let it snow let it snow. :dance:
Thanks to all the Fog guys for advice and how to posts. :drink:
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Nov 21, 2010 9:59 pm
Remember the photos in the snow when it happens Pete 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Nov 22, 2010 5:46 pm
fixed the radiator with that steel putty,(cheers drift) twin fans installed, (still on a temp switch)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Nov 25, 2010 11:26 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Nov 26, 2010 12:24 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Nov 26, 2010 12:28 am
plans this weekend are, sort the fans out, and maybe just maybe a 2" body lift
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jamez2 on Fri Nov 26, 2010 1:20 am
relocated number plate to door with light
replaced top rad hose, old one was very worse for wear
removed sai pump and wondered if it could be modified to pump up tyres
jamez2
Vehicle Name: Frantera
Modifications: Wind deflectors, rear tints
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Nov 26, 2010 6:43 am
found out i need a new engine
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Fri Nov 26, 2010 9:58 am
Ouch, Dazz. I wouldn't like to hear that. :x
What's wrong with it?
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Fri Nov 26, 2010 5:05 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Fri Nov 26, 2010 7:53 pm
scraped ice from the inside of windscreen - winter is here :roll:
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Nov 26, 2010 9:17 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Fri Nov 26, 2010 11:34 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Fri Nov 26, 2010 11:39 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 26, 2010 11:46 pm
:lol: :lol: :lol:
Nothing to mine but been at that bloody Musso bag of ssshhhhii£ again :roll:
Ged, oh wise one with no ears decides with a cheapo inline heater he can run straight filtered used veg in it no matter what the temp, I told him 4 weeks ago to go 50/50......noooo tight arse new better :roll: anyway, he has waxed his pump
So we change the fuel filter prime it with injector cleaner, I notice the lift pump is sucking to the filter but nothing to the injectors (self bleeding on the 2.9) all the lines heated and a few air bubbles.
He went gung how with easy start, nothing so stopped that sharpish.
Verdict is a waxed pump and some constant heat but not so much as to damage the pump seals and associated pipework.....
I know more about that bloody cars pump than mine, tell you what its the simplest fuel pump you could ever meet (and the owner :roll: ) (Sorry Ged :wink: ) (its okay I wont allow him membership here :lol: ) the pump is simples, mine scares the troosers offa me :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Nov 27, 2010 1:34 am
cant you run a fuel pipe through the cooling system to a tank in the back i saw an american car use it. He basically ran the cooling pipe round the tank an into the system an had a fuel pipe inside it.it kept pipe warm an fuel warm without over heating the oil
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 27, 2010 1:45 am
Tight arse would have to pay for the pipe, did I mention he was tight :lol: :lol:
To be fair he is skint at the moment, but with plans :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Nov 27, 2010 1:55 am
seen some intresting ideas on the old veg oil conversion a guy up used the by product from a chocolate factory for fuel there is a kit for 400 quid for the ethnol conversion
