Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Nov 17, 2010 5:10 pm
I took it to get washed after fixing the window again. went to one of those jet wash things i wasnt washing it forgot how shiny it can be when its clean i havent washed it since the july
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hobsey on Wed Nov 17, 2010 6:17 pm
Been to insideout4x4 today to get my recovery shackles.
hobsey
Vehicle Name: Fanny
Modifications: Air freshener
HD Trooper rear coils
2" coil spacers
265/75/16 Fedima Frontieras
Recovery shackle
Magnamount Aerial
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Kevin1964 on Thu Nov 18, 2010 11:35 pm
Ahhemm cracked my windscreen and it wasn't long ago it was fitted :sick: :sick:
Kevin1964
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Thu Nov 18, 2010 11:38 pm
Modded my air intake at long last to raise it up about 12 inches with some corrugated tubing. I'm pretty sure I can hear the 'suck' of air now, either that or I have developed an exhaust blow at the same time I fitted the airbox pipe :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Nov 18, 2010 11:59 pm
Nothing ....again, its like a car parts whorehouse in my car at the moment, full of lots of goodies I should really fit and sort out :oops:
So as I am servicing a mates petrol Picasso tomorrow and fitting an inline heat thingy to my mates Musso it would be rude not to tickle my car a bit while my oil pants are on :lol:
Gutted my 2.8 wont run on veg :evil: my mate Ged can get 400l for £50 :shock: and we have access to 10 times as much up north a few hours drive 8)
No bloody good for me though grrrr ££££££ :D
Simon, thats your turbo sucking air not your exhaust, you can hear it as you have brought the intake near to you, I think it sounds ace 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Fri Nov 19, 2010 4:47 am
i needed new front shocks but don't have a lot of money this time of year so had a look on ebay for a cheap set for now and found two new front shocks (lip 4x4) for £5 each so ordered them. fitted them on tuesday
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Nov 19, 2010 12:36 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 19, 2010 4:00 pm
We never got around to mine :roll: :lol:
Yer veggie buggers up the pump seals in my engine :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Fri Nov 19, 2010 7:35 pm
Well today I tested the load carrying capacity. Pretty good as it turns out. Must have been well over a tonne of logs/wood in the back today, and the bog standard suspension only dropped about an inch. Couldn't really tell the difference in performance either. Result! :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Nov 19, 2010 8:36 pm
thats betsy away to garage
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 20, 2010 6:38 pm
I think I have stopped the mini oil leak on the front of the Transfer case 8) the only pain was the snapped bolts on the transfer guard grrr two snapped and I had to drill them and replace but jobs a goodn.
I then did a service on a neighbours, thing :oops: a Hyundai 12v thing :lol: got me a case of beer :dance:
Then I cleaned out all the bits from inside my car and banged them in the shed and hen fitted a pair of these to my front doors :D
And got carried away and fitted an inclinometer :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Sat Nov 20, 2010 6:41 pm
I like the electronic compass thingy Ste. Where'd ya get that from :?:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 20, 2010 6:43 pm
Another member was scrapping an MU and its out of his truck 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 20, 2010 6:46 pm
Sorry no, the compass, that was from Ebay, its an inside and outside temp reader and ice alert, also battery volt reader, compass.
It cost a tenner a couple of years ago, I have never seen one the same since :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lurchy666 on Sat Nov 20, 2010 6:50 pm
well gave mine its 3000 mile oil change and while i was at it as it has covered nearly 7 thousand since i changed oil filter changed oil filter , air filter and diesel filter as it was cheaper to buy the 3 as a package off flea bay
just brought 2.5 tds lwb
lurchy666
Modifications: no mods so far
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hobsey on Sat Nov 20, 2010 7:07 pm
Fitted my front recovery shackle.
Couldnt fit my shocks due to losing my locking wheel nut key :twisted: Will have another look for it tomorrow.
hobsey
Vehicle Name: Fanny
2" coil spacers
Recovery shackle
Magnamount Aerial
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Nov 20, 2010 8:46 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Nov 20, 2010 8:55 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BadBoy on Sat Nov 20, 2010 8:58 pm
between yesterday and today
Removed dash and replaced heater matrix - I now have heat (if you can call it that on a 2.8 :lol: ) in the cab :D :D :D :D
Removed head lining and cleaned it
Stripped down the winch mount, rubbed down, primed and repainted
Fitted 12500lb winch :D :D :D :D
Cleaned rubber on sunroof, in hope it will stop the leak :(
Tomorrow - wash, polish, & hoover and weekly levels check
Skype Username: paul.bush21
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Nov 20, 2010 9:08 pm
