Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Mon Mar 30, 2009 7:52 pm
well i have cleaned it :oops: hopefully i will be taking it for an mot next week sometime,once ive sorted bearings and lower ball joints :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Mon Mar 30, 2009 8:04 pm
Oh well, if you have cleaned it you are only one step away from marriage :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Adam on Mon Mar 30, 2009 8:46 pm
still in pain but it was worth it , can't stop look at it :D :D :D
Adam
Vehicle Name: Mini-Monty
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furio on Mon Mar 30, 2009 10:28 pm
Decided to re seal the rear diff pan. the old one looks Ok says I until I attack it with a wire brush to tidy it up a bit and end up punching a hole in it. Oh well I've got a nice new one on now, and all filled up with fresh oil. A big thanks to Drift for his posting about changing the rear diif cover in the how to section, i found it very useful. :wink: Still finding my feet with this spanner wielding business :lol:
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Mon Mar 30, 2009 11:27 pm
Today ;
Topped up rear axle oil,
Re aligned load sensing vale to allow for longer springs (as detailed by Davey Here worked a treat,
Cleaned rear axle breather.
Checked transfer box oil,
Checked gearbox oil.Greased front prop shaf,
Checked fuel filter drain for water (none present as usual)
Removed & binned the remaining bit of first plastic bash plate,
Removed battered second plastic bash plate,
Removed bent front steel bash plate..........
Hit it with a big hammer on the anvil,then refitted,
Started the rear brake & handbrake service.......
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_RAYNET on Mon Mar 30, 2009 11:50 pm
I did a dry run on the light bar i obtained extra cheaply. Still not sure if its too big or not...
I also think i solved my oil leak....
Dave_RAYNET
Modifications: not yet
Skype Username: dave_m0yaa
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Tue Mar 31, 2009 9:34 pm
well after work i changed the drivers side ball joint on the dirty diesel and re adjusted wheel bearing, booked it in for mot on tuesday
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Mar 31, 2009 9:44 pm
Got my new tyre today :dance:
After nearly killing a tyre laning :(
Amazed how little the tyres on the car havent worn in comparison with the new tyre, well happy :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Tue Mar 31, 2009 11:12 pm
I washed it :D :D :D
Well it did have a large quantity of mud on it from a laning session on Sat with fellow fogger Mr Tint :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Mar 31, 2009 11:51 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Mar 31, 2009 11:54 pm
Nope :butt: :lol:
Though he father inlaw did ask if I wanted to take the truck to his depot and fill the tyres with nitrogen :shock:
But didnt see much point as Im airing them up and down each trip and didnt fancy carrying a nitro bottle around :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Mar 31, 2009 11:56 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Apr 01, 2009 12:02 am
Hmmmm :idea: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frontycustoms on Wed Apr 01, 2009 12:27 am
Taxed it :dance: The dynamic duo are back in full affect :lol: :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Apr 01, 2009 7:56 am
well i will fitting two of these,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Apr 01, 2009 3:35 pm
Well finally got my :butt: off the floor and found out i really do have a Limited Slip Diff still fitted to my truck (NO andysd1 and Weave) you are not having it :lol: :lol: :lol: got it washed so at least i know now what the burning was the other day (filled diff with EP90 :oh yer: ) so next job flush and refill with proper stuff
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Wed Apr 01, 2009 4:01 pm
Well today i bin busy takin the towbar off me old fronty and cleaned it up and gave it a lick of paint, while i was in the mood for painting i took the bullbar of the new fronty and painted that too!!!
Will post piccie of the bullbar when its back on the truck.
Its back on !!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by SPEEDBIRD 202 on Wed Apr 01, 2009 4:13 pm
Down to the local car wash in me lunch break, £6.50 for the Platenium Wash.
The 5th Gear television programme did some research in to car washes
1st up, was the Jet Wash [they said no good]
2nd up, the people you visit who have a Bucket and lots of Workers giving it the once over [they said not very good]
3rd up, the Car Wash you get at your local garage, the drive-through type [they said very good].
Apparently it leaves less scratches in your paintwork Image
SPEEDBIRD 202
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Wed Apr 01, 2009 4:38 pm
Finally finished fettling the new A Bar brackets and got it fitted.....oooooooohhhh she looks lovely again 8) 8) 8)
