Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Oct 23, 2010 12:37 am
Yep same as mate...I like his spare lack of wheel! :lol: I know he's got beadlocks but they are a pain in the but to undo, and refit with the new tyre...My Landcrusier ones took a couple of goes at least to get em to seal :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Oct 23, 2010 12:45 am
He built that from scratch but it needed trailering everywhere as it was to slow and expensive to drive on the road even though it was legal, he sold it soon after for top dollar 8)
He used gas for the tyres :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Sat Oct 23, 2010 3:59 am
Yes jas ill get you one too :drink: :party: :butt: :drink:
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Oct 23, 2010 4:00 pm
Nipped up the wheel bearings that I replaced last week and moved the stone guard from rubbing on the disc, and cleaned the boot contents up a bit :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Oct 23, 2010 4:15 pm
Another boring Saturday so decided to go through the forest. Forestry wagons had been up there and carved two very deep ruts which was nice, with some nice sideways moments in 2WD. Enough to scare the kids anyway :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Sat Oct 23, 2010 7:56 pm
Fixed a pain in the ass coolant leak from a pipe behind the engine above the gearbox. Took ages to find, access, remove, fix, and refit. All because some idiot forgot to replace the hose clip that should of been there. 8 hours of my life effectivly wasted.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Sat Oct 23, 2010 7:57 pm
Today I put new relays in for my air horns and roof bar lights - as they were water damaged. I also changed a couple of connectors.
I pressed the horn......nothing happened. :?: Well, except one side of the roof bar lights came on, it was faint and flickering. So... I put the roof lights on, and... the horn came on and so did the other side of the roof lights. I realised I must have mixed the relays up. Doh!!!!! :roll:
All sorted now though!! :D
I also painted my shackles red! :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Sat Oct 23, 2010 8:12 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Oct 23, 2010 11:26 pm
Finally managed to get the transfer gears out and the new ones in :D :D :D
What a PITA job if you've never done them before :lol:
Someone somewhere mentioned doing the output flange seal on the 2.8 transfer box, its a 36mm nut, good luck with getting it off though, I broke my Snapon breaker bar trying to get the nut off :shock: :shock:
Ended up drilling through the nut on opposite sides and splitting it with a cold chisel :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Oct 23, 2010 11:29 pm
Fixed the li'll white locked up leafer today...
Had replace a powersteering hose and belt...but the adjust had seized so off it came and with a dose of oxy-propane it freed up nicely...
Refitted with new belt and replaced the burst hose with the one liberated from the yella fronterror...
Refilled the system and started her up and we now have powersteering again :dance: No more aching arms!
I rerouted the hose differently to keep it away from the exhaust manifold this time...the burst hose failed on the bit closest to the manifold so I am wondering if heat had been a factor...this car has had an unusual life in the last 14months, such that it has done next to no road miles and hundreds at 5mph with some immense under bonnet temperatures at times...and at 5mphish everywhere there is little air flow to cool the manifold...
We will see if this one lasts longer!
Drained down the cooling system and treated it to some antifreeze...it had been full of water since it blew its rad at the beginning of the summer...
Checked the oil, fixed the drivers door lock and removed the driving lamps to give more airflow and so I dont bust em!...
Ran it up to temp and noticed a pool underneath...though balls I have a leak somewhere..then realised it was petrol...the return hose from the engine to the hard piping had split and I had done a couple of gallons into the engine bay and floor...We noticed a petrol smell from it at the weekender, but thought it was the breathers where the car had been almost on its side...no wonder it used so much fuel last time out!
Finished off with a bit of reshaping with the sledgey...tyre to arch clearances are somewhere near where the should be again now! :lol:
Then started on the 2.8lwb...changed the glowplugs (must take Sally to the workshop next time I do this, my hands are too damn big to get in to em easily!), tightened alternator belt..still too loose really, but end the end of the adjuster...might get a bit shorter belt for it...
Added some more antifreeze, topped up the screen wash, checked levels and topped up where needed, and sorted the headlight out that wasnt working (broken wire at connector where it pushes onto bulb)...
And that was it really...so came home...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Oct 23, 2010 11:30 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sat Oct 23, 2010 11:52 pm
removed all smc badges stickers
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Oct 24, 2010 12:31 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sun Oct 24, 2010 12:33 am
Scottish mud club
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Oct 24, 2010 12:34 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sun Oct 24, 2010 1:14 am
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun Oct 24, 2010 11:53 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jpbiketransport on Sun Oct 24, 2010 12:57 pm
Fitted my new alternator, the old one wouldn't charge the battery when i was using power [lights ect] and i work nights :lol: , Haven't got to put the battery on charge every day now :dance:
jpbiketransport
Vehicle Name: yeep
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Oct 24, 2010 3:27 pm
Bought a new anttena for my cb out of maplins pre tuned with mag mount £17.99, Now if i get stuck when im out on the smc weekend coming up i can least talk to some one or even call for help .
also yesterday i bought a bike rack of a guy on another forum for £20 quid he used it on his fronty apprently can hold four bikes if you squeeze them on i only want it for two bike but extra options are always an added bonus.
Think im all set for a weekend away trailer tent, bike rack and cb roll on the summer
