Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Thu Oct 07, 2010 10:24 pm
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Oct 07, 2010 10:27 pm
I knew it.......
:rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Thu Oct 07, 2010 11:04 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Fri Oct 08, 2010 4:33 pm
Took advantage today, of an early finish and some welcome sunshine...
Ran Holly through the jetwash to wash the mud, etc, off, and especially to clean several years worth of accumulated grime off the roof, now the rack is off. Wouldn't you know it, it's blue under there, too :lol:
Anyway, then proceeded to evict all my junk from the car, and go round with the hoover, and noticed I still have damp carpets on the N/S. Roof lining was dry, however, so I don't know if is this down to my intensive efforts on the roof, or if it's just that the car still hasn't dried out fully from the rain, etc, we've had of late.
Either way, I'll be monitoring things, and hopefully it'll clear up, but I still think my next job will be to strip the interior out and check the roof out properly from the inside. Oh, and sort the cabling runs for rooflights, etc :wink:
Anybody else got any thoughts??
Jim
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Fri Oct 08, 2010 7:40 pm
I was totally surprised to read about the roof issue - I knew there was rust on there when I owned it, but never thought it had gone far enough to have gone pourous.
In the past (over a year or two ago mind you) the sunroof drainage channels had blocked and a heavy rain fall would cause the sunroof recess to fill up and drip into the cabin - that was sorted by periodically running a curtain wire on a cordless drill through the drainage channels (they exit behind the wheel arch liner to the rear of each front wheel well - where the crud accumulates).
There was also the issue of the cracked floor at the front chassis mount points (both sides) in the foot wells - when the cracked bulkhead was welded up, these also got welded up.
The only other water ingress points I experienced with the BBB was the passenger side bulkhead gromet and the gear lever gromet (below the gaiter).
Otherwise, I have no idea.
Good luck with the investigations and cure.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tom on Fri Oct 08, 2010 9:21 pm
well I have been playing with the sport and made up a light bar what do you think
tom
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Fri Oct 08, 2010 9:30 pm
looks nice tom as does the truck :wink: is that your new offroader ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tom on Fri Oct 08, 2010 9:34 pm
no still have "oj" just doing it to sell
tom
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Fri Oct 08, 2010 10:32 pm
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Oct 09, 2010 5:26 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sat Oct 09, 2010 10:08 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sat Oct 09, 2010 1:31 pm
Well, it's been a long time, but I have at long last taken the Sport out for a quick drive around - up to Halfords, petrol station and back.
Changed a blown indicator bulb... er, that's about it.
Did more to the Volvo; replaced both rear indicator bulbs (the orange had badly peeled off the existing ones) and replaced a blown fog light bulb. Oh, and squirted the auxillary belt idler with silicon spray - that fixed the squeek (thank goodness it wasn't the water pump).
Lawrence :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Sat Oct 09, 2010 4:56 pm
Attempted to do the lower ball joints. Couldn't even get the castle nuts off. Failed :(
And now I'm knackered cos I need the truck next Sunday which means I have to try and find somewhere that can do the ball joints and MOT it next Saturday morning :( :(
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sat Oct 09, 2010 7:31 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sat Oct 09, 2010 8:00 pm
Nothing :D but as that is what I nomally do to it thats not really anything new :lol: :lol: :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BoxCleva on Sat Oct 09, 2010 8:19 pm
Noticed a slight exhaust blow on the rear to middle section join. Bought a new gasket. Predictably I had to grind off the bolts as they were totally seized :evil:
Problem is the bolts are captive so have to be ground down and then drilled out :evil: Popped a sanding disc into the grinder to polish the flanges ready for reassembly when the disc ripped , the grinder bounced into my stomach and proceeded to eat my jumper :shock: Thankfully it stopped when it ate half the jumper and I was able to reach the plug and kill it :lol: Wife was full of sympathy when I pulled up my jumper to inspect bodily damage.'' Can't of been that bad it didn't dislodge the fluff in your belly button'' :evil:
Also decided to change the n/s sidelight bulb which is a pain as the airbox obstructs access, so decided to whip off the air assembly. So glad I did! I guess I went even deeper than I realised last week as the bottom of the airbox was full of dried mud :shock: The bottom of the filter is also a nice muddy brown colour, thankfully it would appear that the mud didn't make it through the filter as the top of it is still white. Blew it out with my compressor and slapped it back in.
Need to finish the re drilling of the flange tomorrow and refit the exhaust. Happy days :?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Oct 09, 2010 8:38 pm
started my CV boot replacement, well like i say i stated, striped it down to the axle, its hanging out, then i got distracted by food, will finish it tomorrow
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sat Oct 09, 2010 8:52 pm
Uncovered the Yella Fronterror and attempted to remove the powersteering hoses, only to find I needed a 16mm spanner and didnt have one at home! :twisted: Will bring some home from the workshop tommorow and pillage it to repair the Li'll white locked up leafer... :lol:
Was about to start getting the 2.4i ready for sale, but the sun came out, so took the dog for a nice walk down the beach instead, and sat laughing watching 3 guys trying to launch their jetski thingies into the surf!
Worked out a plan of action for some cunning mods on the 2.8lwb, to be implemented as soon as I get Sallys glitterball fixed so its no longer a daily driver for her! 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Oct 09, 2010 8:55 pm
All I did was stick my finger into the ash tray hole and pulled it out with a bit of glass sticking out of it, seems there is a bulb in it, smashed :oops: ouch :lol:
Other than that baby sitting and gardening :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by lwbant on Sun Oct 10, 2010 8:49 am
not today but through the week i fitted my new disco 2" springs,
discovered leaky fuel pipes behind a silly welded on plate just infront of rear axle so cut out about a foot and replaced with hose,
but when unclipping the fuel pipe the brake pipe next to it fell apart :shock: how lucky?
so half way through replacin both front to rear brake pipes!
lwbant
Modifications: +2" discovery rear springs
front wound up 8turns
flipped upper balljoints
front driving lights
4 light roof bar
Users browsing this forum: No registered users and 41 guests
