Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sun Sep 26, 2010 3:38 pm
Ahh they do look nice seats chap,you got that gearbox sorted yet ??
Not done anything to mine but did put new filter on the drinking water tap so tea tastes soooooooooooo much better 8) :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun Sep 26, 2010 7:12 pm
well she is back together, and road worthy, well almost, just a small mater of a cv boot, and nudge bar,
but she is ready to roll, and she had a bit of a clean
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Sun Sep 26, 2010 7:32 pm
I've done something to my truck today :D - about bloomin time too, as it's been sat still for nigh on 4 months.
Had it MOT'd last week = Fail.
Will go in for repair on Tuesday: some knucke joints on the steering need replacing (badly warn apparently). Failed on emissions, hense the new set of plugs (regapped) and a shot of redex injector cleaner, also tweaked the MAF. New set of rear brake shoes required and possibly a bracke cylinder. And a headlight bulb had blown.
Sounded sweet with the new plugs and tweak - will see what Tuesday brings.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FUDDY MUCKER on Sun Sep 26, 2010 8:03 pm
Trugga, before you take it for a re-test chuck some CATACLEAN into the fuel tank.
The emmissions are most probally high due to a Lazy Cat, especially cos it's stood for so long.
But it also cleans injectors and lambda sensors without any damage.
A 500ml bottle will do, around £15.00 from most good motor factors, and I'm sure it's got a money back guarantee on it as well.
More info here : http://www.cataclean.com/
And if it's any help, It's comes with the "FUDDY SEAL OF APPROVAL" as I've been using it for the past 7 years and new had a car fail on emmissions. :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Sep 26, 2010 8:10 pm
:google:
so far over the last few days i have stripped the dash out, done the re-wiring behind the clocks, done the soldering of the clocks (still not working speedo and everything else only works on the side lights :?: :evil: ), stripped the interior out and gave it a good clean (used to be a smokers car :( ) taken throttle body off and given it a good clean now the accelerator doesnt stick :) done a plastic weld on the radiator then covered with molten plastic and covered that with araldite, hope it lasts. checked all underneath the car (first car i have ever been able to drive up my ramps) now just waiting for friday to tax it and see how she runs. :)
productive weekend me thinks :D
igotababyfrontera
A set of A series rims
(31" kl71's)
40mm Body lift
Flipped top ball joints
Steel belly pans
Rear recovery points
CB radio in glovebox
Rear work lights
1 Farad power cap
H.I.D Headlight Conversion
DVD head unit
Twin amp & Twin sub setup
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Sep 26, 2010 11:03 pm
Good man and decent botches 8) :dance:
its only a botch job if it breaks till then its a legit fix :dance:
if any one got any ideas on those clocks im open to suggestion.
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Sep 26, 2010 11:21 pm
I like your thinking, A series man myself but bang the post in the electrics forum or search through there, should get some answers :wink:
yeah tried that nobody replies even put my own thread up but nothing :( viewtopic.php?f=7&t=36980()
goaana see if i can speak to people on the 5th at the monthly meet (viewtopic.php?f=39&t=37016&p=401260#p401260)
think i got the links right.
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Sep 26, 2010 11:37 pm
yeah the yorkie repair is the one i tried :(
i also went over all the other soldered joins just in case
unfortunately not got a multimeter to check the actual boards but did look thriugh magnifying glass and couldnt find anything
ill have to try the multimeter way over next few days before friday
oh just off the top af your head is it normal for a car to blow all four lights on the back of the clocks (side light lights)
thanks for your help
scott
oh yeah i rekon these posts will have to be removed due to being off tpoic :oops:
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Sep 26, 2010 11:52 pm
To be honest Im not sure with the B's, our old trucks are a tad less fickle in that department.
i gotta admit i like the look of the older clocks a bit better cause they got a voltmeter :) can you fit an old set in to a B?
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Mon Sep 27, 2010 10:20 am
oh well was worth a thought. :(
i think the bulbs might have been down to the last owners bodge :(
igotababyfrontera
(31" kl71's)
40mm Body lift
Steel belly pans
Rear work lights
1 Farad power cap
DVD head unit
Playstation 3
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Stuart69 on Mon Sep 27, 2010 11:50 am
Checked out my steering wobble yesterday and I can move the cv joint side to side. I looked up and got a drip of water in my eye. The water pump has sprung a leak. :roll:
Dropped it off the jacks and went for a :drink: I've only got one usable hand just now after severing the tendons in my finger so repairs have to wait.
Stuart69
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by James Bass on Mon Sep 27, 2010 11:59 am
Just been told that the rear section on my LED beacon bar thingy wasn't working. I gave it a clout, and hey presto. Must have a loose wire. Will have a look at it at work tomorrow when I bring some screwdrivers in. 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Norse on Mon Sep 27, 2010 12:18 pm
IT support/Advice just ask me
Norse
+2" Sus Lift
+2" Body Lift
DIY Snorkle
Shedload of stickers
To do
Boot Organiser construction
Remove spare wheel holder
Perhaps a CB
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Mon Sep 27, 2010 4:57 pm
I DROVE it down the road and back.
First time in two years.
Champagne methinks. :dance: :dance: :drink: :drink: :dance:
Frenchfarmer
It works!!!!
