Engine holding back at 2900rpm
Re: Engine holding back at 2900rpm by andytats on Fri Apr 12, 2013 9:40 pm
Yea that's what I meant :lol: :lol:
Re: Engine holding back at 2900rpm by gregster on Sat Apr 13, 2013 12:37 am
Pull the pipe off the inlet and try it then Andy...It will then be normally aspirated and sluggish, but would eliminate if the turbo is strangling the engine as it will breath straight into the inlet manifold.
Not sure but doesnt the pump open up when its got boost, which would kinda indicate that side of stuff is working if its overfuelling and smoking, unless the probs with the pump maybe.
A long shot, but have you checked the exhaust....reason I say that is that the old iveco 75e15's I used to drive at work used to do exactly the same as your truck when the exhaust brakes stuck on in that they held back, wouldnt rev past 1/2 and smoked like hell...could it be the exhaust is blocked/bent/restricted/baffles collapsed? Easy to check, just undo the exhaust at the front and run it "openheaders" to prove a point...
Re: Engine holding back at 2900rpm by andytats on Sat Apr 13, 2013 3:41 pm
Fixed it :lol:
Today I took off the exhaust manifold and turbo I found the small pipe to the turbo actuator had a small slip in it so changed that then checked the actuator moves by putting an air compressor on the pipe then Put it all back on and went for a test drive to find it has a little bit more power still not happy with that so checked the diaphragm on the injector pump to find it had some dried mud in there so cleaned that out. Then started the engine and pushed the loud pedal all the way down to find that the inlet pipe collapses when on full throttle so I undone the air box and tried again this time it was fine so done the air box up and disconnected the snorkel and it was fine. :lol:
So went for another test drive and its now fine.
So after all the bloody work of taking bits off and cleaning to find it was all down to the snorkel :rotfl: :rotfl: :rotfl:
Re: Engine holding back at 2900rpm by Hound Dog on Sat Apr 13, 2013 4:34 pm
I told you she hand the hump lol.
Glad you got her fixed.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: Engine holding back at 2900rpm by andytats on Sat Apr 13, 2013 10:54 pm
I hate jealous cars :lol: but she has had a seeing too this week so that should keep her happy :rotfl: :rotfl:
Re: Engine holding back at 2900rpm by RatCav on Tue Apr 16, 2013 9:38 am
Dodgy snorkel installer. I would ask for my money back.
