Normally get about 32/34 mpg out of mine doing a good 2k miles a month but with the turbo knacked and an unhealthy interest from the local traffic boys in the 'oil burner' it's sat on the drive and is staying there until fixed.
Took the MX5 (known as the go-kart)to work today instead, have to admit it, it was a slightly different drive...... and to be honest, fun. Must remember not to drive the truck like the go-kart when I get it back on the road though and as for trying to get all the work gear out the truck and into the go-kart....
