DOH! Stripped Sump Thread.
Re: DOH! Stripped Sump Thread. by kingfisher on Mon Dec 08, 2008 8:09 pm
sir doris could you give me a link to uk drills on ebay as i have put in the search box on ebay and nothings coming up , thanks
kingfisher
Vehicle Name: The money pit
Re: DOH! Stripped Sump Thread. by Sir-Doris on Mon Dec 08, 2008 8:37 pm
Il go one better. Drillbit and taps are from UK Drills on Ebay, Bolt and washer are from www.stagonset.co.uk I got a stainless steel bolt and washer, a bit more expensive at about £1.80, but a regular galvanised bolt and washer could be had in a hardware store for about 20P.
14mm Drill bit Ebay number: 250301673742
1st and 2nd Tap Ebay number: 260294168553
For the taps buy 2 and when you come to checkout tell them you want a 1st and 2nd.
And the 16x2.0 Stainless Steel bolt was from here: M16x2.0x25mm Bolt
And I bought a Stainless Steel washer as well: M16 Form A washer
Re: DOH! Stripped Sump Thread. by Drift on Mon Dec 08, 2008 9:28 pm
Handy info Phil 8)
Re: DOH! Stripped Sump Thread. by Sir-Doris on Mon Dec 08, 2008 9:50 pm
It is. Fingers crossed it will all fit together and work as advertised :D :D :D
As mentioned in a previous post, check to see if you have a steel or alloy sump as the steel ones have a bit less material to work with then the alloy ones.
Re: DOH! Stripped Sump Thread. by Drift on Mon Dec 08, 2008 9:57 pm
For those with the 2.8 this is what your dealing with
inside view
Re: DOH! Stripped Sump Thread. by Sir-Doris on Mon Dec 08, 2008 10:18 pm
As you can all see from Ste's pics the pressed steel sump just has a metal collar welded to the sump and it doesnt have much material to work with.
Goo pic Ste.
Re: DOH! Stripped Sump Thread. by kingfisher on Tue Dec 09, 2008 1:17 am
mines not lke that , so i must have the alloy sump . thanks for the info sir doris. i will order them now thanks mick
kingfisher
