Frontera Technical Support • View topic - MUD MUNCHA'S Sick !!!!!
Re: MUD MUNCHA'S Sick !!!!! by alex on Wed Apr 23, 2008 8:39 am
Its easy to get dissolusioned (spelling?) when its not working. Cant see the wiring suddenly going off, if its always been run on LPG since you got it and now on petrol theres issues I wonder if there are 2 problems, not connected. I would be tempted to sort starting on lpg first as you know it has run on the lpg, then look to the petrol.
Dropping the exhaust at the cat for a quick spell is an idea, sorry but engines aint my area.
Re: MUD MUNCHA'S Sick !!!!! by Drift on Wed Apr 23, 2008 8:41 am
Might as well take the cat out and weld in a pipe, its not need as its a toy :wink: could get a tad more power to 8)
Re: MUD MUNCHA'S Sick !!!!! by FUDDY MUCKER on Wed Apr 23, 2008 9:37 am
Re: MUD MUNCHA'S Sick !!!!! by FUDDY MUCKER on Wed Apr 23, 2008 10:36 am
Good News, well sort of.
Managed to fire it up this morning, again after a battle. and thought I would turn it around in the drive, so instead of the front pointing down to the bottom of the drive (drive has a slight slope, maybe about 1 foot in about 18 foot over all length) to front would be facing up hill to a degree.
Drove it out, just, with hand over snorkle managed to turn it around and drive it back in the drive. got out and noticed some rather pretty multicoloured rainbow patches on the wet drop down drive bit. On closer examination it seems that the Reason there was no petrol in it when I brought it was because it was dumping it on the road when the engine was running, due to the fuel pipe been split at the fuel filter tank side end. Just cut the spilt out and re attached it, new jubilee clip and tried it. Seems alot smoother on tick over, still hesitates but will now accelerate (just) when you plant your foot to the floor over 2500 rpms.
Still dont explain the lack for running on LPG but its a start.
Re: MUD MUNCHA'S Sick !!!!! by bobbinsjob on Wed Apr 23, 2008 11:45 am
keep going Jase, you'll fix it, I'm sure
Re: MUD MUNCHA'S Sick !!!!! by Road Hog on Wed Apr 23, 2008 12:08 pm
Morning bud,try putting a new set of spark plugs in,they may well be breaking down under load.
Re: MUD MUNCHA'S Sick !!!!! by alex on Wed Apr 23, 2008 12:17 pm
Hasnt the other truck got a good set of leads and plugs.
Re: MUD MUNCHA'S Sick !!!!! by FUDDY MUCKER on Wed Apr 23, 2008 12:33 pm
Re: MUD MUNCHA'S Sick !!!!! by Red Oktober on Wed Apr 23, 2008 12:37 pm
are you having it pressure tested jase ......
Re: MUD MUNCHA'S Sick !!!!! by Drift on Wed Apr 23, 2008 5:48 pm
Chuck some Forte seal rejuvinator in the oil, if the seals aint to far gone that will help :wink:
Re: MUD MUNCHA'S Sick !!!!! by brachunky on Wed Apr 23, 2008 5:53 pm
3 inch suspension lift
31 10.5 Muds
Re: MUD MUNCHA'S Sick !!!!! by Drift on Wed Apr 23, 2008 6:19 pm
Not sure but it will only work if the seal is not complketly shot but could be worth a try , check here
http://www.forteuk.co.uk/
It sorted a slight oil leak on mine about 18 months ago :D bone dry since 8)
Re: MUD MUNCHA'S Sick !!!!! by 4x4 bobby on Wed Apr 23, 2008 9:45 pm
I know weve allready spoke. But from what i just read reminds me of my 2stroke genny. When i finish useing it i turn of the fuel and let it run on so it uses up the excess fuel in the carb, just as its about to run out the engine revs up then dies. Wich basically means the fuel mix has got week and its drawing the wrong fuel to air ratio. This is what you said happend to mudmuncha. He seems to me to be getting to much air not enough fuel so dont discount the fuel pump not giving you the correct pressure all of the time. As for the LPG Are you one hundred % sure it has got fuel and the gauge aint knackerd cause i woulnt trust it with all that bad wireing. I'll try and get to you tomorow ok mate. Keep your chin up.
I'LL GIVE YOU £50 FOR IT!!!!!!!!!!!!!!!!!!!! "Ha Ha"
Rob :oh yer: :oh yer: :oh yer: :oh yer: :oh yer: :oh yer: :oh yer:
Re: MUD MUNCHA'S Sick !!!!! by Drift on Wed Apr 23, 2008 9:46 pm
Hmmm the lamba senor, then.
Re: MUD MUNCHA'S Sick !!!!! by Road Hog on Thu Apr 24, 2008 12:13 am
Not the Lamda Ste,it senses content of exhaust gases & then adjust air/fuel ratio to suit. So the engine has to be running for it to work,failed Lambda normally has erratic/fluctuating idle speed.
Re: MUD MUNCHA'S Sick !!!!! by FUDDY MUCKER on Thu Apr 24, 2008 7:03 am
Re: MUD MUNCHA'S Sick !!!!! by alex on Thu Apr 24, 2008 7:08 am
Jase,
You dropped the exhaust yet?
Re: MUD MUNCHA'S Sick !!!!! by FUDDY MUCKER on Thu Apr 24, 2008 8:32 am
Re: MUD MUNCHA'S Sick !!!!! by Road Hog on Thu Apr 24, 2008 8:39 am
Re: MUD MUNCHA'S Sick !!!!! by Big Dave on Thu Apr 24, 2008 10:04 am
Big Dave
_____________________________________
Fronty 94 SWB Sport 2.0i - Broke it
Little Blue Van 96 SWB Sport S 2.8TDi - Sold it
Member of http://www.northtyne4x4.com http://www.4x4uk.org
Big Dave
Vehicle Name: Honda Civic
Modifications: Dreams
