Frontera Technical Support • View topic - Brake Pipe Replacement -Alchamist
by I Live For FOG on Sat Jan 26, 2008 5:58 pm
A legend in my own mind
I Live For FOG
by Alchamist on Sat Jan 26, 2008 6:00 pm
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
by I Live For FOG on Sat Jan 26, 2008 6:04 pm
I Live For FOG
by alex on Sat Jan 26, 2008 7:05 pm
Looks very oily around front diff, can only asume problems with it or tranny if someone went to the trouble of removing the drive.does it engage 4wd if turned by hand? might be worth jacking both fronts off ground and turning it to see if they drive before searching for a prop.
Glad the rest is going well.
by Alchamist on Sat Jan 26, 2008 8:04 pm
Jay
Alchamist
Modifications: .
* CB
by I Live For FOG on Sat Jan 26, 2008 8:52 pm
you dont think your going to be that lucky do you :lol: answer no but later 2.0 will fit :wink:
I Live For FOG
by john boy on Sun Jan 27, 2008 9:02 am
I can get down to you 1st march to sort out the hinge. i can make a plate for in the pillar and we will nibble away the inner panel to acess the pins. cut the old ones off and renew and if you get a prop get the bolts as well. if you call the place i give you the number of they will remove it if it's still on the vehicle. but as alex said if you get both front wheels off the ground and twist the flange clockwise just to see if the hub locks work and the diff moves. both front wheels should lock and rotate in the same direction may take a sharp snatch to lock the hubs.let us know how you go on.
by Alchamist on Mon Jan 28, 2008 5:51 pm
Jay
Alchamist
Modifications: .
* CB
by alex on Mon Jan 28, 2008 8:57 pm
There was a lot of work done by the look. With some luck (and you are due some) it could just want some more bleeding or the pads to bed back in.
by Alchamist on Mon Jan 28, 2008 9:13 pm
Anyone want to make pancakes? With the lemon that is my fronty, I should have plenty of juice! :lol:
Jay
Alchamist
Modifications: .
* CB
by Alchamist on Sun Feb 03, 2008 10:26 am
Ok - Round 2 today all being well. John has offered to come over again! (He clearly didn't have enough punishment last time, or the coffee was that good)
Hopefully we can find out where the brakes are sticking today, and if I we have long enough I will see if I can test that front axle of mine.
Wish us luck! :lol:
Jay
Alchamist
Modifications: .
* CB
by Red Oktober on Sun Feb 03, 2008 10:32 am
Good luck Jay ...and John :D :D :D :D
by Alchamist on Sun Feb 03, 2008 11:36 am
Jay
Alchamist
Modifications: .
* CB
by Red Oktober on Sun Feb 03, 2008 11:39 am
by Drift on Sun Feb 03, 2008 8:32 pm
by alex on Sun Feb 03, 2008 8:34 pm
