Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Tue Jun 15, 2010 9:04 am
it did have 235/75/15 on it and they looked weedy i think the measured up at 29 inch diameter :D
as i had the pepper pots with 255/75/15 (31inch diameter) tyres on i stuck them on
they clear the wheel arch's OK but slightly rub on full lock on the step front side support bar i will undo the support bracket & give it a clout with a big sledge hammer to bend/push back a touch :drink:
i reckon the fronty pepper pot brought the tyre out about 4 to 5 inch's thats why i fitted the arch extensions
Ive just got to put 2 strips of ally checker plate on the 2 rear doors to finish it off then give the rear & the roof a go with T' cut and then a good going with mer polish
then i will fit a set of mudflaps
when the sliver paint on the sides has had a chance to harden it will get a going over with fine wet & dry then a going over with mer polish
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Tue Jun 15, 2010 9:12 am
I would be inclined to use something like 3m Perfect-it compound between wet flatting and Mer polishing mate...will save much arm ache and will bring the flatted and dulled new paint back much easier than going straight to waxing.. :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Jun 15, 2010 9:27 am
My Trooper had 205/80 R16's on. Looked like it was on pram wheels. Currently using 255/65 R16's which are a bit meatier though getting close to rubbing. Was going to get some spacers, but looking at the offset of those pepperpots I think I will just get some new wheels and keep the old ones as spares.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Tue Jun 15, 2010 9:28 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rod 4x4 on Tue Jun 15, 2010 8:07 pm
today i fixed my leaking back diff. power washed the underside of the truck so i can it it painted. fitted a new prop shaft coupling. and spent 200 quid on 2 new tyres [insa turbo saharas 31/10.50] bloomin mot lol :roll:
93 2.4i brutus the hillbilly express
rod 4x4
Vehicle Name: brutus
Region: Northern Ireland
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Tue Jun 15, 2010 9:52 pm
not today, but over the weekend;
- extended bracket for rear brake line T fitting to ensure rear flexible isnt stretched
- made and fitted lower spring retaining brackets
- cut down the shock gaitors so they only cover loosely at normal running - full of Bala mud!! deffo recomend to anyone off roading to do this....
- modified the anti- roll bar ends for temporary quick release to see the difference, rear seems worthwhile but havent seen much benefit from front
now just need to plan the time to do the front end rebuild :shock:
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Jun 15, 2010 10:24 pm
The chevy brava looking good. showed it to the wife an said that what i want she said NO NO you cant have one :twisted:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jun 16, 2010 1:39 am
I finished wiring up the roof lights wired it under the roof lining and fitted the two switches next to the interior light i ran the earth through the interior light earth i ran the live under the bonnet an up the inner door seal an through a wee cut out on the pillar up the inside of the plastic moulding along the inside of the roof lining to the switch. i took a live from the switch to the lights along the roof lining to the top corner of the door frame through a wee cut out then along the outer seal to the roof light bar. I earthed the earth of the spots to the mounting bolts using eye/loop connectors. The switches light up when the lights are on.
i also fitted new washer jets a set of chrome ones with amber leds i temporary wired the ive to the fuse an the the other wire to a earth strap they come on with the side lights an look good, i have done this as a temp cause i want to see if the police will give me a dig if they do i can disconnect them then an there. If i have to i will fit a switch.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Jun 16, 2010 1:42 am
Looking good mate... 8) 8) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Wed Jun 16, 2010 1:50 am
cheers shame the middle light still of center , and the switch squinty lol all easy fixes
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Wed Jun 16, 2010 8:40 pm
Change relay for light bar,fixed the front spot,lose wire,
Jobs to do next
full service
ball joints
clutch and crank shaft seal
Tracking
and :twisted: the the MOT
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Jun 16, 2010 9:21 pm
got some lovely light covers when i was in London
and a second wheel cover
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Jun 16, 2010 9:55 pm
finaly fixed the broken brake pipe, filled the diff, its all go again,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Jun 16, 2010 10:22 pm
Measured up the chevy with regards to the impending live axle swap...and its gonna all fit nicely using patrol leafs and axle up front (SOA of course!) and the rear is looking good too using patrol rear and soa on the chevy springs...
Measured for extra rear crossmember carrying 2nd transfer case (nissan again) and with about 15degrees of axle clocking the rear the rear prop should sit nice...
By provisional calculations there should be just about enough clearance for the 38.5x16x15 superswamper boggers....bonnet height should be about chin height (and I am 6'1" 8) )
Its gonna be a monster, might even be the biggest fronty out there (its gonna get a fronty facelift with grill and lights when I paint it as the isuzu stuff is battered!)...and will actually work offroad unlike most of them prettied up Hilux's!
Might need to extract some more GeeGee's from the 2.8 though...thinking of fronty intercooler set up and turbo if it will fit..
Ifitted new clutch slave cylinder but still think it needs a proper bleed, changes gear great but think the bite is still too high
Livewire Frontera
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Jun 17, 2010 10:25 am
Fitted a set of metal tyre valves as the rubber ones keep leaking. Hopefully that will cure the flat tyre every two days.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Thu Jun 17, 2010 12:30 pm
Well, my new spotties turned up today, so I've been out swapping things over on the roofrack...
I now have 4 of these beauties mounted up there, eBay clicky, as I've always preferred those style of lights to round ones.
Now just got to whip the rooflining out, and sort out the cabling... I must be feeling a bit dense this morning, as I'm looking at em (only one wire coming out) and going "budumbudumbudum" etc, hehe :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Jun 17, 2010 5:52 pm
picture of the finished lights n switches please wilber
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Jun 17, 2010 6:23 pm
i took some picture of how i did mine to help other who may choose to do it not saying my way is best of full proof as i only done it yesterday
As you can see the wire from the lights sit`s nice behind the outer door seal out of site except when the door is open but that not a big issue to me
If i lift the seal to show you you can see its route
from above there is no wire showing
i then ran it through the inner seal on the door frame through a cut out in the metal that is already there
this hides the wire nicely an stops it fouling on the door. inside it looks neat as it run along the head cloth
for the live its the same i ran it along the inner wing to where the bonnet wing an pillar meet i ran it under the outer seal to a wee notch cut out on the pillar frame that allowed it to pass under the inner seal
i then ran the live wire to the switch along the plastic moulding to the roof an between the roof cloth an roof to the switch. when you close the door its all nice an neat inside an outside.
Last edited by drinksoptional on Thu Jun 17, 2010 6:26 pm, edited 1 time in total.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Thu Jun 17, 2010 6:25 pm
Finally managed to figure out why the caravan kept losing its right indicator. After spending ages puling all the panels apart and finding a forest of scotch locks everywher, then properly soldering them together, it still didn't work properly. Then took a look at the truck itself and found yet another scotch lock splicing the right indicator wire that was shorting out. Pulled all the bleeding things off and again soldered the lot. Everything flashes and buzzes as it should ... winner!
Think I must of removed about 25-30 scotch locks in total now :( God I hate those things :evil:
