Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Fri Jun 11, 2010 12:42 pm
Well I was going of on a journey to do some work (rarer than the Dodo) then got caught up in the traffic jam for THIS hey ho another skint week :( :wall:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Fri Jun 11, 2010 1:31 pm
Replaced the nearside rear brake piston that went bang and dumped brake fluid all over the road. Skimmed drums up and fitted new shoes bled system all round, truck stops well now. :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Fri Jun 11, 2010 4:04 pm
Took the truck into Mach and back for some cigarette filters. So thats probably 250 miles Iv covered in it in the last 3 months :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Jun 11, 2010 4:54 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Jun 11, 2010 6:05 pm
put a new tail gate on as other one hinges broke its black get it painted some other time could not believe how heavy it was when fitting
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jun 11, 2010 10:30 pm
Been there done that Daz, they are heavy suckers, imagine the weight with the wheel on :shock: no wonder hinges go on them.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Jun 11, 2010 10:35 pm
might save the amp and cd player for the new car, :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Jun 11, 2010 10:57 pm
Its nearly today, so Im going to wash mine as under it is filthy, and fix my compressor then refurbish some calipers, get new rear discs next week then should be MOT acceptable :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Fri Jun 11, 2010 11:41 pm
if all goes to plan tomorrow, i may be frontyless, for a while.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Fri Jun 11, 2010 11:45 pm
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Jun 12, 2010 12:05 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sat Jun 12, 2010 2:32 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat Jun 12, 2010 6:36 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Sat Jun 12, 2010 5:17 pm
Cleaned my screenwash jets. Amazing amount of crud in them. So much in fact that the rear one died from the pressure of trying to force it all out. Also replaced my rear speakers so I can get bass again and tightened a couple of loose bolts underneath so no more clunk noises. Rattling is still there though and I can't find anything else loose :evil:
furball
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Jun 12, 2010 8:47 pm
i wired my roof lights up just to decided where to put the switch panle an route the wires thinking head cloth next to interior light
Canny wait till night time to light my driveway up. i swapped the round ones on the front for the rectangle ones which is alot better looking with one snag canny get the truck in the garage fitted with the rectangle ons but with the round no chance may have to cut two round hole out the garage :D least they work couple of extra screw just to make sure the bar is properly secured to the body
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sat Jun 12, 2010 8:58 pm
that looks cracking mate got my roof lights on but not sure how to wire them got wiring kits just crap with electrics
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Jun 12, 2010 9:04 pm
so am i at the moment they work directly off the battery three inside are on one circuit via fuse n switch an the outside on another via fuse an switch, will work them into the full beam circuit when i can be bothered :P
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sat Jun 12, 2010 9:24 pm
still looks the b@'lcks
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sun Jun 13, 2010 8:28 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by N1ova on Sun Jun 13, 2010 9:44 am
Sprayed the metal bit under the rear lights,on the diesel lwb.Looking good now.Will put it back on this afternoon. :D
N1ova
Vehicle Name: Blue flash
