Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Mon Mar 16, 2009 1:44 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FUDDY MUCKER on Mon Mar 16, 2009 9:16 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Mar 16, 2009 9:22 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FUDDY MUCKER on Mon Mar 16, 2009 9:31 am
:sick: :sick: :sick:
I draw the line at growing a beard !!! :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Mar 16, 2009 9:39 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by FUDDY MUCKER on Mon Mar 16, 2009 10:45 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Mar 16, 2009 12:39 pm
A friend has soft lips,
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Mon Mar 16, 2009 1:11 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Mar 16, 2009 5:27 pm
:offtopic:
Re: WHAT YOU DID TO YOUR CAR TODAY! by dandan on Mon Mar 16, 2009 6:32 pm
Well I finally managed to get the Rover firing up under it's own power :dance: :dance:
After an hour of very systematic deduction, it turned out to be a loose connection between starter motor and ignition :oh yer:
Also discovered that I need a temp gauge sender unit :roll: and that my aux drive belt is quite difficult to get hold of :?
Still plenty more I can be getting on with :D
If you're sat there thinking things just can't get any worse, just wait......
dandan
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Mar 16, 2009 8:01 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by damrabbit on Mon Mar 16, 2009 8:21 pm
re-fitted (bodged) the vacuum tank that i mistakenly removed while fitting pikey snorkel yesterday
i once again have brakes :dance:
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Mar 16, 2009 8:24 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Mar 16, 2009 8:25 pm
Think they are only on the 2.8's
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Mon Mar 16, 2009 8:27 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Mar 16, 2009 8:29 pm
In that case get it going and check the brakes, rather important its there
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Mon Mar 16, 2009 8:36 pm
well today i stripped both my front driveshafts and auto hubs,cleaned all the old grease out ,Messy job,then rebuilt the lot using semi synthetic grease i liberated from work :wink: for the auto hubs i gave them a good clean and used a little engine oil on re assembly,aint i a good boy :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Mon Mar 16, 2009 8:39 pm
Well done Weavy boy :dance: all set for the weekend :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Mon Mar 16, 2009 8:40 pm
oh yeah roll on the weekend :dance: :drink: :party: :sick:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Mon Mar 16, 2009 9:59 pm
Yesterday on a whim (up at Bobby4x4's to collect some woo woo's) I decided to remove the bash plate of the SWB - 8 bolts and it was off (I was going to take it off any way, but decided to do it with plenty of assistance to call upon should it be needed)
Then I realised - how was I going to transport it home... With a bit of head scratching, Alchamist managed to get it in the back of the sport on it's side, between the front seat and the roll cage, with only a bit sticking out the rear window (which had to be removed).
New exhaust being fitted Thursday, then refit the bash plate and of to Whales we go.
