Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Fri May 07, 2010 10:57 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat May 08, 2010 7:27 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by country_Est on Sat May 08, 2010 9:55 am
Bobster,
Not reporting your post or anything like that, was just wondering why it was done thats all.
As for grovelling about under water then I agree totaly but tend to fitt mine with the stops thru the rear window and front onto the roof, but only fit them when I am going off road, but dont have them on at all times. Just wondering how much easier it is to find the shackel that the hole any way thats all.
Every body has there own ways of doing things and | just like to know why some things are done, if a any reason at all or just to look good.
Trev
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat May 08, 2010 10:00 am
Oh ok sorry Trev i just saw Repot this post and wonderd why. A lot of us find it easier to have them fitted permanantly and i think they look good too.
Sorry again for jumping Trev.
Bobster.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by horses45 on Sat May 08, 2010 10:24 am
just to but in i like the look of them and makes it easier for me to connect my straps when im off roading and green laning plus did i say i like the look of them :D .now in this thread of what i have done on my truck i will be taking Audra to her first day at work then i shall be fixing the lights and spraying them blue. :wink: or trying to.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Sat May 08, 2010 10:59 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat May 08, 2010 5:42 pm
My 2 danglies sit out on thr front in all weather. Occasionally get some copperslip for them, but itsa spanner to open them, I dont usually mess with them.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Sat May 08, 2010 7:22 pm
Sold the little black 2.8, didn't realy want it to go, but would rather it be used than sitting doing nothing. Hope it made it home with no dramas'.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by simo_d on Sat May 08, 2010 7:51 pm
Cleaned off all the welsh mud then put my fog stickers off tom
simo_d
AKA The Cosmic Fool
AKA The Cosmic Fool
Vehicle Name: Elizabeth
Modifications: 2"lift,
buckshot mudders
air horn
yellow bash plates :)
internal snorkel
light guards all around
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by N1ova on Sat May 08, 2010 8:30 pm
Took the gearbox out.Still none the wiser as to why i only have 4th gear.Pressure plate and clutch in mint condition. :?
N1ova
Vehicle Name: Blue flash
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sat May 08, 2010 9:28 pm
From your fault description it will be the actual gearbox that is at fault not the clutch.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by domino on Sat May 08, 2010 9:38 pm
Sorted the oil pressure sender.
Tidied the side step with the help of a wire brush and tin of black spray paint.
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat May 08, 2010 11:04 pm
Washed the outside and rubber mats, gave the inside a good vacuum but the carpets are still soggy from Saturday :roll:
Checked and adjusted the front tracking and discovered the new steering arm I fitted is also bent :?
Rear diff is now leaking so off with the cover tomorrow morning to see why
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat May 08, 2010 11:48 pm
I went off roading at an abandoned farm with my new tyres met a drunk bloke on a mini crosser who showed me round
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sat May 08, 2010 11:48 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sun May 09, 2010 12:32 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by tucker on Sun May 09, 2010 9:39 am
Hi everyone
I gave the truck a mini service,air filter,diesel filter,but i let ATS do the oil & filter change.
it seems to go much better for it.a slight problem has occured with the window wipers,the intermitent seems to have stopped working and the normal wipers don't park where they should,i'am not sure what's going on,i'll get them checked out.if anyone has any idea's how to fix them, i'am all ears :) .
Tucker...2.2 DTI Irmscher.
tucker
Vehicle Name: costaplenty
Modifications: Irmscher pack, Window air deflectors,sound deading in all the doors,& under the bonnet.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun May 09, 2010 6:00 pm
I went up dukes path an through the queens forest drive along the 3 lochs forest drive
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Sun May 09, 2010 6:47 pm
started the rebuild of the dash
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun May 09, 2010 6:58 pm
I finally got all the detritus from Bala out of the car and did a few checks and all is well :dance: so I tidied the shed did the garden then got drunk 8)
Users browsing this forum: Google [Bot] and 34 guests
