Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Apr 28, 2010 5:01 pm
I may have some side step bolts here, think they are the same, remind me if you need them :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by vargas on Wed Apr 28, 2010 5:06 pm
2" coil lift
Wound up torsion bars
Wired up new spot lights
Finally got tyre put onto spare rim
vargas
Modifications: Falken Landair/AT 31/10.5/15
Midland 98 plus CB
2" coil lift
Uprated recovery points front + rear
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 2much on Wed Apr 28, 2010 8:13 pm
just fitted new rear shox for bala, rough country. hope theyll be ok they seem to be about 20000inches longer than stock :shock:
2much
Modifications: 2much!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Wed Apr 28, 2010 9:42 pm
Changed rear brake pads :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trugga on Thu Apr 29, 2010 3:24 pm
Washed it, removed roof lights and fitted waffle boards to roof (dry mud now all over the newly washed roof :oops: )
Refitted passenger seat, removed spot lamps (one was wobbly)
Cleaned ICV, topped up steering fuid (other fluids checked and ok)
Cleaned a lot of junk out in preparation for loading it with more junk tomorrow.
Removed and refitted top windscreen trim.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 29, 2010 3:32 pm
Today i started to put my camping gear in,and on the roof,i had to use the step ladders to put stuff on the rack :oops:
I just hope i can get it of again when i get to Bala :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Thu Apr 29, 2010 3:38 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 29, 2010 3:46 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by domino on Thu Apr 29, 2010 3:58 pm
Today I reversed my Frontera into a sign post.. bent the sign post and scratched the side step.
Oops :)
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by damrabbit on Thu Apr 29, 2010 3:58 pm
Filled it with diesel then filled it with camping gear ready for the off :v happy: :drink: :to much: :4x4: :beer: :drink: :to much:
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Thu Apr 29, 2010 4:12 pm
loaded the crates of Stella in the truck....£10 for 24x330ml bottles at Tesco :party:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Apr 29, 2010 4:21 pm
Well got the new handbrake cables, fited them ajusted them up and wow i got brakes!!!!!!!!!! Thats a first!!!!!!!!!!!!!
See you at Bala People!!!!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Thu Apr 29, 2010 4:25 pm
re-checked fluids, tyre pressures and made sure that the sleeping bag is in the truck...so if i forget the tent..not a problem...also put big fishing brolly in, and a pack of digestives. Jobs a good un..
still got to check the circlips and re-seal the auto hubs, but it's raining and I ain't got a garage. going to get on with packing a bag.
I'm in no way excited about Bala.. :dirty w/end:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Thu Apr 29, 2010 4:32 pm
......:excited:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by headbanging on Thu Apr 29, 2010 4:37 pm
headbanging
wound up torsion bars (2")
flipped top ball joints,
roof light pod
blue-tooth CD player
modified side repeaters
smoked tail lights
uprated turbo hoses
Skype Username: BadgesPatches
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Apr 29, 2010 6:44 pm
Bought 40 cans of stella at asda £9 for 20 cans :shock: :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Thu Apr 29, 2010 7:24 pm
Ran a full can of carburettor cleaner through the intake and added some injection cleaner to the diesel tank. The truck immediately ran quieter and with increased throttle respons. God knows how much power I'm going to get after the injector cleaner has done it's job as well :) I've aready got like a new truck with lots of power after my engine flush a few weeks ago :-D
Love it ! :dance:
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Apr 29, 2010 7:26 pm
Nice one Erik, you need those EGR valve off now and the particulate filter :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 29, 2010 9:00 pm
I found an oil leak coming from the front of the engine somewhere its higher than the sump gasket from what i could see, Add to the list.
Dropped the glass out my square spotlight leaves me three square chrome ones and two round ones so i put them on a light bar.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Apr 29, 2010 9:06 pm
Drinks if its the rear it could be the rocker cover, they are known for this, if not that it could be the rear crank case seal, thats a gearbox out jobby but if its not too bad leave it and check oil every week should be fine then if changing clutch change the seal or visa versa.
