Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 15, 2010 4:00 pm
HMMMMMMMMMM :roll: NO
But they was bloody long and trying to push down on them to get them into the holes on the body was a nightmare.
Did you fit yours.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by colley on Thu Apr 15, 2010 4:09 pm
Will have to fit mine a night in the week :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 15, 2010 4:38 pm
I attempted to change the rear shocks an got stuck at the first hurdle the bottom nut came off, the top one would not budge at all siezed solid gave it a good soak with dw40 and it still tight as !!! i gave up and put the bottom nut back on got a feling i may have to goto a garage an get them to get the air ratchet on it or some heat.
Oh joy
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 15, 2010 4:52 pm
WD40 ok i brought some Plus Gas Formula its very good,my front shock bolts wore solid on ,i sprayed some on left 5min and crack came undone :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Thu Apr 15, 2010 4:55 pm
Plus Gas is far & away the better release agent WD40 scores more points in the waterproofing department :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 15, 2010 5:16 pm
Where do i get plus gas? and how much is it?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Apr 15, 2010 5:16 pm
My rear exhaust tail pipe is hanging off, snapped on the way home from work :roll: so just ordered a new one on ebay £18 delivered opposed to milners £26ish delivered :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 15, 2010 5:17 pm
not bad
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 15, 2010 5:33 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Thu Apr 15, 2010 6:06 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Thu Apr 15, 2010 7:11 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Thu Apr 15, 2010 7:16 pm
Yes they do A friend....use it myself sometimes, have a can ere, but must admit oxy-acetylene works better at freeing stuff up...
Plusgas is only marginally better than wd40 or soaking in diesel...
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Thu Apr 15, 2010 7:29 pm
I used to refill my old tin with white spirit,marvellous "creeping" properties & cheap,the really long spout made it super handy for squirting into awkward places
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Apr 15, 2010 7:38 pm
Now gregster this is me your talking about me and burning gear would not be a good idea.
First no bolts for bullbar then siezed shocker bolts now i lost both my 8mm sockets so i cannot do light bar
I say kiss my :butt: thursday
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Lee_R on Fri Apr 16, 2010 8:38 am
Fuel tank dropped out, split from carrier, cleaned, rehosed and refitted. Carrier, diff, axles and all surrounding chassis/bodywork coated in waxoil whilst I could get to it.
Hopefully no more leaking diesel from a full tank...
Lee_R
Registration Year: 1992/K
New rear leaf springs
Wheels refurbished
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontydan on Fri Apr 16, 2010 11:00 pm
Yet again removed the rear wheel to try and resolve the binding issues following the diff swap..............
Now just about ready to say :butt: :butt: :butt: to the truck and go at it with a bloody big hammer but might settle for a branch off a nearby tree, a la Basil Fawlty.
At times i hate Fronties, and at times i love 'em but by god this one would try the patience of a saint. :twisted: :twisted: :twisted:
Given up for today and will settle for getting p@@@ed.
Dan
Member number 4669
frontydan
Bill
Bill
Vehicle Name: The bus
Body lift, 2".
3" suspension lift.
Blue LED dash conversion.
Waffle boards x 2.
AVM Manual locking hubs.
De Catted..... 'Cos i can !!!
Stickers akimbo.
To Follow...........
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Apr 16, 2010 11:37 pm
I saw a damp patch on my rear diff and went ah well put it on the list of things that are wrong with my fronty i need to figure out what it is and how to sort
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Apr 16, 2010 11:41 pm
Drinks, see here :wink:
viewtopic.php?f=41&t=984
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Apr 17, 2010 12:22 am
cheers drift i didnt see the how to tell the wife i need to spend £50.
Last time i done a diff was on a tilt cab bedford truck in 1994
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sat Apr 17, 2010 12:28 am
They are more in the region of £60 now :( but it just may need resealing, also check the breather is not blocked :wink:
