Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Tue Mar 16, 2010 8:15 pm
Washed yesterday and given a serious polishing this afternoon. Have identified some areas thet need rust treating. :DMechanics first then bodywork as the weather improves.
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Tue Mar 16, 2010 8:37 pm
Removed and repainted front grill, removed front bumper and hammerited front crossmember. Fixed broken fog light wiring. Took apart previous owners birds nest stereo wiring attempt, raced all the speaker wires, and soldered them onto correct ISO plugs. Swore at the state of the bumpewr and considering getting a new one as opposed to getting this tin worn riddled thing cleaned, filled and painted ... Then again might just go for an aftermarket one with winch and recovery point mounts.
Pics (I know I know ... its a Mk.1 Trooper, but I used to own a Frontera, and at least this Trooper has the 2.8TD 4JB1T so there is some similarity)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by th4neuk on Tue Mar 16, 2010 8:39 pm
fitted my new sidesteps,
Sorted.
Just need a nudge bar now
Alan
Alan
th4neuk
Sidesteps
Rear privacy glass stuff
Tweaked torsion bar
BFG AT's
Extra reversing lights
Wish List
Rear Spring +2"
+2" Shocks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dodge on Tue Mar 16, 2010 10:24 pm
well............. not really to my truck but for my truck
picked up sids wheels off mega-fronty who i now owe lots of beers!!! :drink: :drink: :drink: cheers mate
time to jack bert up and get these things on!!! (they are rather big) those who have seen sid will know what i mean!!!!
dodge
Vehicle Name: "bert"
Modifications: suspension lift
1200w sub/amp package
bluetooth headunit
33 x 12.5 x 15 hankooks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dodge on Wed Mar 17, 2010 2:50 pm
and followed up by some before and after shots. will get some better ones up soon, these are off my phone!!
spot the difference
thats better!!!
and a couple from the lickey hills!!!
dodge
bluetooth headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Wed Mar 17, 2010 3:30 pm
Looks good mate
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Mar 17, 2010 3:45 pm
Took here in for the MOT this morning. Awaiting the impending call of doom :D :D :D
Fingers crossed, checked everything I could think of and she just had new suspension bits on the front so should be ok. Just the usual annual worry and aggravation.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Mar 17, 2010 6:04 pm
TYPICAL! :evil: :evil: :evil:
Just called the garage to see how the truck had done and they said that the auxiliary belt tensioner had given up the ghost in the last 3/4 of the emissions test.
Gonna drop round tomorrow morn with a new belt and tensioner from the spares truck (which has already paid for itself).
The good news is everything else had passed and the emissions were looking good until the tensioner let go :D
It appears that the 2 things my truck likes to eat are starter motors and aux belt tensioners.
5 starters and this will be my 4th tensioner in 7 years of ownership.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Mar 17, 2010 6:10 pm
:oh yer: at least nothing too expensive :drink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by RatCav on Wed Mar 17, 2010 7:26 pm
Pulled the nudge bars off the front bumper and stripped them to metal. Gave them a coat of silver paint and was not impressed with the finish. Will smooth them down and get a coat of black on them and go from there.
Pulled apart the wiring for the tow electrics and found the socket was one large lump of rusty metal. Grabbed a spare socket and made a good job of it. Works fine now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Kevin1964 on Wed Mar 17, 2010 7:55 pm
Managed to do some work on the 2.5 Fronty today by fixing the steering colum wobble....Turned out to be the typical loose top fixing bolts.
I also managed to remove the 2.5 heads today only to find one is cracked causing my coolant problems which aint good but hey ho will have to get hold of another one sometime.
Kevin1964
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Wed Mar 17, 2010 9:12 pm
Fitted new top BJ`s,no more clonk`s :dance: :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Mar 17, 2010 11:30 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Mar 17, 2010 11:35 pm
What could be better :lol: 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Wed Mar 17, 2010 11:41 pm
Took the 2.8lwb for its MOT today..... :shock: :shock: :shock:
And it PASSED :dance: :dance: :dance: :dance:
couple of advisories...
windscreen chip just out of zone a
ball joint rubbers split but no excessive play
split cv gaiter... :shock: (but he let me off as I pointed out it was a 2wd drive car on the road...and hence MOT as it was on a road...so they are only cosmetic...he laughed and I promised to do it soon) 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Wed Mar 17, 2010 11:46 pm
Fitted some S/H front shocks kindly donated by Sir Doris,wayyyyyyyyyyy less nodding donkey syndrome :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Mar 18, 2010 2:24 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by adyclemo on Thu Mar 18, 2010 9:10 am
dReplaced and relocated rear diff breather to the engine bay and replaced the front one for good measure and extended it rounf to the drivers side so if i decide to put a snorkle on it the breather pipes can be tapped into that. Filled the rear diff back up with oil as it was empty. Happy days :D .
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Thu Mar 18, 2010 10:24 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Fri Mar 19, 2010 11:40 am
In keeping with the MOT surprises Iv now got another 12 months of motoring to look forward to with the old girl.
2 advisories, rear brake pipes (Front to rear) slightly corroded and rear most fuel pipes slightly corroded.
Oddly enough the dicky body mount wasnt even mentioned and the emissions were way less then then expected so it seems I can drive the old girl without fear of murdering the ickle butterflies or retribution from the tree huggers.
