Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Wed Feb 24, 2010 11:07 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Feb 24, 2010 11:14 pm
It certainly was, we nearly broke FOG and put the world to rights :rotfl: :rotfl: :party:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Feb 25, 2010 1:24 am
Got the welder out and started my exhaust project.
After checking the cat and exhaust on the spares truck I realised they are 63mm tubes. I thought they looked a bit bigger then the ones on the old girl so I measured up. The exhaust and cat on the Old Girl are 54mm.
The spares truck centre baffle was shot so I cut that off with a 9" angle grinder, got some exhaust tube from the local exhaust place and set about cutting and welding. Just got the final measuring to do now, Il tack the exhaust flanges with everything bolted to the truck and remove the exhaust for final welding so I get a good fit.
Just in time too cause my exhaust manifold gasket is blowing a wee bit on startup so it was lucky that I received a new manifold from Fronty 4x4 today, the one without the holes so now I can get rid of the Secondary air injection system, match the manifold and head to the gasket ports and hopefully get a little boost in torque from the increased bore size.
Been using 1.6mm rods and a DC inverter Arc welder. Reasonable results. Perhaps not as neat as they could be but no slag inclusion or blowing through yet.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Feb 25, 2010 1:27 am
As I was reading that I was thinking "I hope he used the wider pipe""I hope he used the wider pipe""I hope he used the wider pipe"...phew, you did :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Feb 25, 2010 1:42 am
But of course Ste, What else was I going to use?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Thu Feb 25, 2010 1:47 am
My new neighbour, Tom, from Ireland via not far from where I grew up in southern Scotland ,has a wee trailer thing that looks like a road drill compressor but is actually a diesel powered stick welder with a special arc starting thing and can handle seriously BIG welding rods and Little ones too.
I like my new neighbour. PURR PUURR
No more "Pigeon Poo" welding his machine is intelligent.
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Thu Feb 25, 2010 7:19 am
Got the 4wd working by listening to A friend :oh yer:
She now runs perfect and even starts 1st time, must have been my muck up with the vac piupes that was causing start-up probs aswell :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Feb 25, 2010 11:01 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by marlbororman on Thu Feb 25, 2010 2:36 pm
Got my aircon fixed, got my new 265 75 16 tyres fitted, Just gotta do the heated switch mod, then everything is done and working on my fronty, spot on.
Then just nipped out and some blonde bimbo in a 52 plate corsa reversed smack bang into the rear of it :( Gawd how i laughed at the dint in her tail gate where the rear mounted high lift jack stoved it in :):):) :roll: :lol: :lol: :lol: :lol: No damage at all to mine :lol: :lol: :lol:
Member no. 705
marlbororman
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by SPEEDBIRD 202 on Thu Feb 25, 2010 2:48 pm
SPEEDBIRD 202
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Feb 25, 2010 3:02 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by marlbororman on Thu Feb 25, 2010 3:40 pm
Yep and because its lifted nearly a foot higher than standard, if the jack hadnt been there, she`d of hit the bar the towbar attaches too :):):)
Member no. 705
marlbororman
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Thu Feb 25, 2010 8:14 pm
Thats exactly what happened when the VW Caddy hit the back of my truck. His is dead mine still lives!!!!!!!!!!!! Long Live the Fronty!!!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 25, 2010 10:00 pm
while out in the slush last night so much for the snow i noticed despite there been atleast £25 of fuel the fuel light was on and the guage showed empty. Today dropped the tank again finding out i forgot to cut slats for water on the tank gurd cover i made, removed all the hoses and connector dragged tank out removed sender unit. When i put it in i never checked it what i had done was knocked the float rod past the wee lug that stops it from dropping down completely popped it back in place tank on works great. Hour labour on the deck im getting better.
Put in a an old cd player does the job. Did try fit the sports steering wheel it didnt fit must need a different boss thing
Last edited by drinksoptional on Thu Feb 25, 2010 10:52 pm, edited 1 time in total.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Thu Feb 25, 2010 10:47 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Thu Feb 25, 2010 10:54 pm
:lol: If i hurt my self one more time this month i will be the one replaced she say`s. :cry:
Last three weeks head injury then done my back in then the eye injury.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Thu Feb 25, 2010 11:24 pm
For the second time in 12months had a good tidy up inside the shorty. Found a few sockets and spanners that I thought I'd lost (and replaced). Fitted a set of cheap seat covers that some one bought me for chrimbo and a brand new air freshener.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Fri Feb 26, 2010 12:42 am
Amazing how many tools you find in there i made £1.40 gained two hose clip star screw driver and an 11mm impact.
Im going to buy a cheap set of covers and get those iron on transfers for them.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Fri Feb 26, 2010 8:14 am
Changed the wheels ready for the weekend.
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
You cant polish a t*rd..
if its broken - fix it
if it isnt - mod it!
jammywagonwheel
Organic Modifications
Vehicle Name: Martha Farquah
Modifications: #1 - Martha
passed MOT,
new front pads & calipers
Broke it
Bled,
Sworn,
Cried,
Hit it with hammers
Fixed it
Users browsing this forum: Google [Bot] and 30 guests
