Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Smallandfurry on Sun Jan 31, 2010 11:38 pm
Take your finger out of there and go wash it!
Smallandfurry
Vehicle Name: in negotiation!
Modifications: Falken Radial A/T's and umm,, it has a nudge bar with spot lights :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Mon Feb 01, 2010 12:01 am
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Mon Feb 01, 2010 7:50 pm
tried to replace front disc's and pads today
everything was going great until i got to the two bolts that hold the caliper housing on :(
couldn't undo them no matter what i tried, so had to put everthing back together and book it in at local garage :cry:
but did manage to get longer shackles on one side of rear :D
do other side tomorrow
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Mon Feb 01, 2010 8:00 pm
Tecnically the titanic did make it throught the ice it just sank 2hr later as a result of hitting the ice,.
Well i did nothing to my frontera today. except move it back into the driveway
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Mon Feb 01, 2010 8:06 pm
I used my fronty today to go to work... the 'short' way, there was lots of snow, and at 7am, I was the first one to drive on it :dance:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BadBoy on Mon Feb 01, 2010 9:05 pm
I bought it :dance:
Well my third one. Now I have 2 :D
Skype Username: paul.bush21
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Mon Feb 01, 2010 10:28 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bushwacker on Mon Feb 01, 2010 10:54 pm
bushwacker
Vehicle Name: ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Mon Feb 01, 2010 11:55 pm
6 drawer chest with storage underneath Reduced from £110 to 50
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Tue Feb 02, 2010 12:14 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Tue Feb 02, 2010 12:25 am
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Trotter on Tue Feb 02, 2010 12:27 am
I had my 15 Point Check done at Nationwide in Warrington for free!
See "15 Point Check" in The Lounge!
Noli Illegitimi Carborundum
Trotter
Registration Year: 1992/K
Vehicle Name: The Burgundy Bus
Skype Username: rodney.craik
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Tue Feb 02, 2010 12:38 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Feb 02, 2010 7:11 am
well i sprayed the back bumper black as well as wrap round wired up parrot did it last night
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by paul01 on Tue Feb 02, 2010 8:05 pm
well i did the other shackle today :)
and adjusted the torsion bars to match :D
changed the oil and filter
cleaned down engine and guard
and repainted the rear diff :D
now i need to lie down :roll:
paul01
Vehicle Name: ?
Modifications: none
yet :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frenchfarmer on Tue Feb 02, 2010 10:09 pm
Frenchfarmer
It works!!!!
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Wed Feb 03, 2010 12:10 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Wed Feb 03, 2010 7:02 am
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Wed Feb 03, 2010 8:27 pm
Well today....
I took off the sump guard so I could re-paint it. This is a job I've been meaning to do since the wales weekender.
also checked around for any loose bolts / cables etc...found one of the starter bolts a little loose..well very loose..I could undo it with my fingers :shock: and also found one of the bell housing bolts in the same state ,double :shock:
all my fault by the way, I think that i may have been a bit hastey in finishing up when I done the rear crank seal.
will pop some before and after piccies of the sump guard tomorrow (I'm in work tonight and can't get piccies off phone and into photobucket on this machine)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by BadBoy on Wed Feb 03, 2010 9:26 pm
