Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Smallandfurry on Sat Jan 30, 2010 6:58 pm
Does driving it through the river crossing at Redbournbury mill count!? possibly the most adventurous thing i've done so far by myself,,,,,,, *hangs head in shame* but it was a good laugh
Take your finger out of there and go wash it!
Smallandfurry
Vehicle Name: in negotiation!
Modifications: Falken Radial A/T's and umm,, it has a nudge bar with spot lights :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Sat Jan 30, 2010 7:52 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by N1ova on Sat Jan 30, 2010 7:57 pm
I done 2 oil and filter changes on mine and my dads fronteras.Done now till easter then ill drop it again. :D
N1ova
Vehicle Name: Blue flash
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bushwacker on Sat Jan 30, 2010 8:02 pm
bushwacker
Vehicle Name: ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sat Jan 30, 2010 8:48 pm
Sunny and dry for a change so got under both for the first time in a long time.
The B has lost its rear box, I had a little moment of madness Friday down some small roads and it party company after a little air. Also the rear drivers shock mount needed tightening (what is it with shock mounts at the mo?) Also put new rear pads in and gave all bushes a good lube. May even put the front prop back on.
The A had some TLC and I found a small water leak from a jubilee clip where I bypassed the second stat in the water loop. Oh and found the 10l jerry can of water in the boot has lost most of it, so did the best to dry hat up.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sat Jan 30, 2010 8:49 pm
ouch hope your finger mend ok.
I moved it out the driveway starting it using my new battery just so i could do some mot work for a mates sister on her astra mk4, man it was cold today and i ripped my favroite old denims
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by yaki on Sat Jan 30, 2010 10:29 pm
Fitted 2 new front flexi hoses as my posh braided ones had sprung a leak :shock:
Inner CV gaiter had split so changed that as well
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sat Jan 30, 2010 11:02 pm
got some new fuel pipe as mine seems to be leaking on the sports yet again
if not to cold will do tomorrow :drink:
also reset a BMW 318 service light on dash
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woods52 on Sun Jan 31, 2010 12:18 am
Got three of the four windows working, last one is stuck solid, will come out next week.
Gearbox is out, though five of the six clutch cover bolts are stuck solid. I will use an impact driver to remove next week
Rear light was replaced.
Started looking for the drain on the battery by removing all the fuses one by one and seeing how the drain on the drain changed, no luck.
woods52
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sun Jan 31, 2010 1:49 am
going to fit new front pads in morning if not too cold :butt:
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Sun Jan 31, 2010 1:10 pm
well done the front pads happy days all done ,done the discs too
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Wilberforce on Sun Jan 31, 2010 9:43 pm
Well, today's been a busy day for Lara, my SWB toy...
First job upon arriving at Chez Gregster, was to swap out the driver's seat for another which Pete (Retro Pedro) had kindly donated, as the bottom of mine had basically collapsed and it almost felt like I was sitting on the floor.
Secondly, with some guidance and assitance from Greg, removed the front auto hubs, and fitted a set of AVM manuals in their place (thank you Andysd1 for those mate)
Finally, and big thank you to Greg and Kel for this one (cos it was mostly them doing it, minor assistance from me :oops: ) the 2" coil spacers went on the rear end.
I was planning on leaving it like that, to get a bit of a dragster look going on, but whilst I was busy with the tape measure in the FOG-Bog, Greg disappeared under the front of my car, and wound up the torsion bars. Boo, hiss, etc.
Anyhow, thanks to Greg, and Kel for their assistance today, and to Pete for the seat. Just got to get my Insa Special Tracks fitted, and we're sorted for the weekender now :mrgreen:
Jim
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jan 31, 2010 9:57 pm
Stuck my stickers on 8)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Krusher on Sun Jan 31, 2010 9:58 pm
The 2.8 got its suspension lift today at Gregsters workshop. After what can only be described as a "slow start", the coils spacers got fitted with thanks
to greg and his spring clamps. We also were kept in good supply of teas and coffee from Gregsters boss Sal so thanks go to her also. I must say that the fronty
on the way home from Gregs seems alot more firm and not as wollowy as before so all good.....
All in all was a good day today with everyone pitching in with each others work, proper team effort. Great...... :wink: :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by V6POWER on Sun Jan 31, 2010 10:06 pm
I smashed both front spots ,one head light, one fog ligh, the number plate and ripped all the foam open on the bottom of the nudge bar.
That was fun!
V6POWER
2" suspention lift.
removed side steps.
uprated recovery points.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jan 31, 2010 10:17 pm
Has someone been driving through frozen puddles then :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by V6POWER on Sun Jan 31, 2010 10:46 pm
LOL how did you guess?
It was only after i got half way through about a 40 foot of section of frozen water that i started to raelise the resistance of the 2 inch thick ice was causing me to stop so i floored it and the final section was a couple of feet deep. When i was out the other side i got out and checked the damage and theres quite a bit more than what i listed like the bumber and smashed grill.
Moral of this tale? Dont drive through frozen deep water with your foot to the floor in 2nd gear low range.
:dance:
Ill show you some piccys 2moz, youll have a good laff.
V6POWER
2" suspention lift.
removed side steps.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Jan 31, 2010 10:48 pm
:lol: :lol: thought as much, we live and learn :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Sun Jan 31, 2010 10:58 pm
rename your frontera the titanic me thinks
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by kees on Sun Jan 31, 2010 11:03 pm
The Titanic never made it through the ice
kees
Now sold, A series Frontera.
FOG sticker
1997/ p reg 2.2i
Now sold.
