Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jason on Wed Dec 02, 2009 7:09 pm
Put new tow bar electrics on and had i looked at the manifold
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Wed Dec 02, 2009 7:28 pm
Performed some diagnostic tests on the various sensors to try and pinpoint the dreaded EML. Discovered a lazy Lambda sensor which was giving an almost permanent lean condition so I took it out and cleaned it up by soaking the tip in Gunk degreaser then scrubbing with a toothbrush before rinsing with some water.
Put it back in, left it disconnected for the time being and started the car. Set the engine speed to 2000rpm for 5 mins to dry the sensor. Switched off and reconnected the lambda. Started her up and the lambda is now switching between rich and lean conditions very quickly indeed.
Unfortunately while doing this a small section of rubber hose (approx 3") which goes from the heater matrix to the head burst showering the engine bay with steam and coolant. I had a look at the donor car for a spare and would you believe its one of two hoses the previous owner had cut to get the head off :(
New one on order ($1.75) and should have it by friday. It is a different size at each end unfortunately so I couldnt replace it with anything I had in the garage.
Just glad it happened in the garage and not while out somewhere.
On a side note about Lambda sensors. I found a web article HERE that said a lambda sensor takes a reading from the exhaust gas and the outside air. I have never heard of this before so gave the outside a good clean with gunk as well. At the end of the sensor where the wires protrude there is a ring of small holes around the sensor, whether these are for testing the external air or not I dont know but would be interested in hearing your info on this.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by hipplew on Wed Dec 02, 2009 8:10 pm
Well the "Guttless Wonder" my fronty has had a new lease of life thanks to me doing the inlet manifold just got the turbo hose's, to do :lol: :lol:
hipplew
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by midge on Wed Dec 02, 2009 8:10 pm
Collected new key from local garage, loaded Freya onto my mates trailer and set off to the nearest Opel dealer. 20 minutes later Freya is plugged into thier computer and the key was programmed to the car. Freya lives, total cost so far 250 euros for the car, 80 for the key and 25 for the programming.
She sounds as sweet as can be, and from the quick drive I had is absolutely sorted.
Next stop take her for a CT (french MOT), insure her and then get her french registered (thanks westo123 for the info on eurococ for the certificate of conformity)
By early new year should have her completely legal and on the road
Many thanks to all who have answered my posts, would never have got this far without you
Fifi - purple 1995 2.0i sport. Freya - black 1996 2.0 sport apache
midge
Vehicle Name: Freya & Fifi
Modifications: None to date
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Wed Dec 02, 2009 8:26 pm
Oh yes me spring have landed for greenie +2" and £35 for the two had em off a guy on monkeys :D :D :D form a company called dobson in oz heavy duty as well :D :D :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Hound Dog on Thu Dec 03, 2009 4:00 pm
let the wife take her to work! doh! :(
Hound Dogs Tractor
Hound Dogs Tractor Comments
Hound Dog
Missing In Action
Missing In Action
Vehicle Name: Tractor
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Sat Dec 05, 2009 10:05 pm
took mine to the tip, brought her home. couldn't get her over the edge of the skip............plus the man there said "it leaks too much oil"
so chucked all the old rubbish out, so i'm stuck with the mobile oil slick for now.
(only joking I love me fronty and I will not be defeated by an oil leak)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Sun Dec 06, 2009 6:50 pm
Welded up a new rear exhaust section for the old one rotted away.
I didn't find any reasonably priced from dealers, so I bought some universial parts and clamped and welded it up :dance: The universal parts with that big a silencer was available only in 2,5" and 3", so I had to go with bigger pipes... Was really sad about that :lol: 8)
Think it looks a lot cooler with the large straight pipe than with the old one pointed downwards.
A bit larger size, the new one :-)
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sun Dec 06, 2009 7:14 pm
8) Excellent job there Mr.Wolf :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Mon Dec 07, 2009 8:18 am
Cheap as well :D
Silencer, 2"-2,5" piece, 90, 45 and 30 degree standard clamped bends, a 90 degree short bend for welding (trimmed down to, 60-70 degrees?), 50cm section of straight tube and four clamps: £90 in Norway. The workshops charged around £450 for the job :evil: :butt:
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Tue Dec 08, 2009 1:00 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MrWolf on Tue Dec 08, 2009 8:07 am
MrWolf
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Tue Dec 08, 2009 8:30 am
They can be taken off and straightened, odd chance they are cranked, as after market cranked arms are available but I think they are only available from stinkyfab in the states.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Tue Dec 08, 2009 2:29 pm
In theory provided both the arms are bent to the same degree then I dont see any problems (MOT tester may pick it up?) but if both are different then the rear axle wont be square to the chassis, only by a very small amount but it might be enough to wear the rear tires.
However a bend may weaken them. They are hollow after all.
I replaced one of mine not so long ago after an accident, took about 5 minutes. 1 big nut and bolt each end and a small bolt holding the handbrake cable clamp in place.
As it such an easy part to remove I cant see a scrapyard charging much for them.
Reason: added a bit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by drinksoptional on Tue Dec 08, 2009 5:45 pm
Fitted the white clips and headlight , the put the grill back on. Need a bolt for the tank guard so was unable to complete the rebuild
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Dec 09, 2009 3:13 pm
Did notyhing to mine, but I changed the pads an discs on her Picasso, it was unbelievably easy, less than half hour each side and thats including the chats with everyone who walked past out of the close :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Wed Dec 09, 2009 7:24 pm
Today I decided to get rid of Stan (the 2.2), was a really hard decision, still have Pindy, have traded him against something, erm, cheaper to run :( am quite gutted, will still have him for a couple of weeks, will be very upset when he goes
I have had to write it somewhere to make me face up to it :(
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Dec 09, 2009 8:28 pm
What have you got :shock:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by cheekychick on Wed Dec 09, 2009 8:36 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Wed Dec 09, 2009 8:44 pm
As long as your keeping the sport thats good by me :D
