Re: WHAT YOU DID TO YOUR TRUCK TODAY! by frontydan on Sat Nov 28, 2009 9:09 pm
Collected it and brought it home.......................Oh sorry forgot to mention it's a 2.4i LWB oh yes we are a 2 truck family again 8) :D :D
Dan
Member number 4669
frontydan
Bill
Bill
Vehicle Name: The bus
Body lift, 2".
3" suspension lift.
Blue LED dash conversion.
Waffle boards x 2.
AVM Manual locking hubs.
De Catted..... 'Cos i can !!!
Stickers akimbo.
To Follow...........
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sat Nov 28, 2009 9:15 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Sun Nov 29, 2009 2:31 am
Said..... hello stranger .....to the glow plug warning light,have not seen it for 10 months :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Dave_RAYNET on Sun Nov 29, 2009 3:05 am
I put my "new" calliper on, bled the brakes and took it for a run.
Also with the help of a mate located the source of my rubbling noise at the back :dance: Drivers side rear brakes are rubbing.
Dave_RAYNET
Modifications: not yet
Skype Username: dave_m0yaa
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john (smifffy) on Sun Nov 29, 2009 11:33 am
i put some anti freeze in the trooper & the sports that should cover them for the winter
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by damrabbit on Sun Nov 29, 2009 2:16 pm
tightened the fan belt to stop the squeeling that developed at the last laning session
Refitted a tube to fanblower so i have now proper air ciculation again
Cleaned and dryed indicator connection that was causing indicator not to work also caused during last laning session (big red fronty has a lot to answer for :wink: )
Cleaned it :shock: :shock:
Looked at lwb lights units to do conversion but put them back in garage,gave up and had a cuppa :D
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by gregster on Sun Nov 29, 2009 7:19 pm
Swapped the wheels n tyres over from the 2.4i to the 2.5tds....
The 2.5tds is now sporting a lots more grippy set of Camac a/t's... 8) 8) 8)
The 2.4 sulking in the background as it now has cr4p tyres!!! :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Alfie on Sun Nov 29, 2009 10:41 pm
I put some petrol in it and went for a drive.First time I have been fit enough to drive properly since august. I drove around the blackcountry and some country roads in staffordshire and really enjoyed myself. :D :D
Vehicle Name: Dino
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sun Nov 29, 2009 10:53 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sun Nov 29, 2009 10:54 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sun Nov 29, 2009 10:55 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andytats on Mon Nov 30, 2009 12:02 am
i had a problem with my heater (only got cool air) the top matrix pipe got hot and the bottom 1 stayed cold
so i Flush & backflush the entire cooling system repeatedly until clear water flows freely in both directions,then fill with water & antifreeze now i have hot air in the cab. job done :)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by 4x4 bobby on Mon Nov 30, 2009 11:12 am
Well this weekend i insured the truck again and took it for a drive to Wigan to pick up a trailer and its running fine, the only problem i got is where its bin stood for so long the the rear brakes are binding a bit. Good to have it back on the road again.
Catch ya all laters
Bobster
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by damrabbit on Mon Nov 30, 2009 5:33 pm
,32mm wheel spacers
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Mon Nov 30, 2009 5:40 pm
Ta mate, just checking. Mine doesnt seem as warm as it should be and im sure the blower used to blow hotter air much faster then it does now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Mon Nov 30, 2009 5:58 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Mon Nov 30, 2009 8:34 pm
Just sat in mine and watched dvd's(cant do much else at the moment :lol: )
Roll on tuesday morning as the new oil pump gears arrive then :dance: :dance:
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Mon Nov 30, 2009 10:18 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jmc on Mon Nov 30, 2009 11:18 pm
Well its colder again and mine is not so quick to start.Last time this meant new glowplugs, but can I find when I changed them? I log just about everything I do on it, but must have missed this out. Went to see a mechanic and booked it in for an mot this friday and discussed replacing the steering idler.Ambled onto work where it sat outside the workshop til I went home in it.Definately going better after its Bournemouth trip last Sunday.
jmc
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bigdazz on Tue Dec 01, 2009 7:55 pm
4 ne w rims and rubber
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Users browsing this forum: Google [Bot] and 94 guests
