Re: WHAT YOU DID TO YOUR TRUCK TODAY! by quiteone on Mon Nov 23, 2009 4:04 pm
Not today but yesterday
refitted inlet manifold after cleaning, fitted new gasket.
Amazing how many bolts you find missing, there was one bolt holding the coil pack onto the manifold, so have replaced missing ones.
Removed exhaust manifold cleaned down and repainted. (This is one of the jobs I've been meaning to do since I had the new exhaust manifold fitted, found that one of the studs had been broken and a monkey job done on it :evil: so making up special fitment stud here at work)
Today ordered new 'o' rings for the injectors and them rubbery washer things for the fuel rail.
Looks like I have to replace one of the injectors due to the monkey cowboys that had it apart before not looking to see how the plug was connected and broke of the little shield whilst removing it :evil: :twisted:
Some jobs you wish you had just never started
Gaz
quiteone
Modifications: K&N Panel filter.
"A" bar and spots refitted.
Wind deflectors.
4 branch performance Exhaust Manifold
and a stinky bear called Rufus.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Tue Nov 24, 2009 9:38 pm
Today i stripped the oil pump to see if that is the reason for the loss of oil pressure and oil light flickering on, and found this...
6 hours later after getting the wet n dry out it now looks like this...
hopefully that will solve the problem
Vehicle Name: Tessie 2
Modifications: Tinted windows
4G WiFi
dvd/cd/radio headunit
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Tue Nov 24, 2009 11:24 pm
fitted a side light bulb :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by domino on Wed Nov 25, 2009 12:09 am
pumped up 2 flat tyres.. ready to get the new ones fitted on Monday :S
Plugged it into the laptop to check everything's running fine and it is. Took it round the block a few times and remembered how much I love driving it.
bring on Monday!
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by andysd1 on Wed Nov 25, 2009 6:37 pm
drove her home, (thanks simo for the lift) my god she shifts
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Wed Nov 25, 2009 6:42 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by V6Jon on Thu Nov 26, 2009 11:55 am
Just dropped it off for a service.
Not normally a big deal, but to the best of my knowledge it is over two years since it was last done, so a little concerned about what this might cost me.
Ah well, will just have to wait and see !
V6Jon
Registration Year: 2002/52
Vehicle Name: George
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Nov 26, 2009 5:13 pm
Ordered a new clutch kit (116 quid delivered). Release bearing is shot and its been about 70,000 miles since the last clutch was fitted so it makes sense to do the whole lot.
Its in the garage at the moment drying out as the carpets are wet and soggy from my recovery adventure last week along with a proper dunking last Sunday.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by fogman on Thu Nov 26, 2009 5:38 pm
changed my thermostat/housing for a lower temperature one, all new antifreeze/coolant as well so im all ready for winter :wink:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Nov 26, 2009 5:47 pm
Bin the carpets Phil :D
If I would have known earlier I could have popped down to help with your clutch change :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Thu Nov 26, 2009 5:52 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Thu Nov 26, 2009 6:29 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jontera on Fri Nov 27, 2009 7:23 am
Replaced my front discs and pads, so now I can stop abit better...actually alot better. hardest part was getting that darn circlip out of the hubs.
Done them yesterday really as it's only 6.20am wet and dark right now.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by rancidrich on Fri Nov 27, 2009 6:15 pm
Shopped around looking for new oil pump gears for tessie today.
Ended up going to the local vauxhall "stealers" who say they have some :dance: :dance: , £36 pounds later it was ordered but have to wait till tuesday for delivery :(
4G WiFi
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 27, 2009 6:29 pm
Stuck new side light bulbs in, feeble but thats all that was wrong with it :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Road Hog on Fri Nov 27, 2009 6:43 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 27, 2009 6:51 pm
Yer but bet you didnt do what I did :oops:
Went to test them (was in works car park) though bugger the whole electrical system has gone down :shock:
I forgot to put that huge battery back in :oops: :oops: :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by woodwizzard on Fri Nov 27, 2009 7:17 pm
Don't sound like you Ste :wink: :oh yer:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Fri Nov 27, 2009 8:52 pm
Liar Jim :lol: :lol: :lol: :oops:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Sir-Doris on Sat Nov 28, 2009 2:04 am
