Frontera Technical Support • View topic - cambelt failure
cambelt failure
Re: cambelt failure by furio on Wed Jul 22, 2015 9:01 pm
OK will do. Need to get hold of a compression tester now. Thanks for the replies, will update as and when.
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Re: cambelt failure by gregster on Wed Jul 22, 2015 9:32 pm
If you havent got one, and its all timed back up on the belt, you could just try and start it. if its got low compression on one or more cylinders then it become apparant as they engine will appear to misfire like its got a lead off. You have nothing to loose really, you are highly unlikely to do any more damage than would already be done.
Re: cambelt failure by Retro Pedro on Wed Jul 22, 2015 9:46 pm
Re: cambelt failure by furio on Sun Jul 26, 2015 7:19 pm
Had a good go at the truck today, working under a fishing brolly over the engine bay :roll: . Rocker cover off and rotated cam shaft, all looked Ok. Rotated crank with spark plugs removed also felt OK. So on with an old cambelt and water pump off my donor truck and she fired up straight away no problems :dance: Ordered a new cam belt kit off ebay so will swap it all over and take her for a spin. Will flush the rad before the new coolant goes in an' all. So fingers crossed I've got away with it. Time will tell but feeling a bit happier now. Thanks for all the help and advice can always rely on good old FOG :thumbup:
furio
Roof lights
Re: cambelt failure by gregster on Sun Jul 26, 2015 8:10 pm
Great news....well done fella :drink: :drink: :drink:
Re: cambelt failure by 4x4 bobby on Sun Jul 26, 2015 9:20 pm
:wink: we told ya!!!!!!! Well done mate!!!! :thumbup:
Re: cambelt failure by snapper on Mon Jul 27, 2015 1:09 am
Good news matey, well done.
