A Series bumpers replacement
Re: A Series bumpers replacement by jmc on Sat Nov 15, 2014 9:04 pm
If you have any thick brass about it can help to put it behind the thin piece you are welding and if you blow through it will still fill the hole with just the weld but it won't stick to the brass which you can take away afterwards leaving just the steel.
jmc
Re: A Series bumpers replacement by titchfield9 on Fri Nov 21, 2014 8:58 am
Cheers all for the information, so far thanks to others on here and a lot of phone calls now have a full set of bumpers that don't need welding and the very dodgy patch done at the garage on the seal is grinding down OK.
Also managed to get a 'new old stock' set of side steps as well for a very reasonable price.
The old girl should look good once back together.
Perhaps it may be worth while a thread on welders!
titchfield9
Vehicle Name: Beast
Modifications: Standard car
