[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Most favourite
If I had a 2.2 I would get a number plate with 4 zero's or O's in the middle...so at a push I could cut them out and fashion myself a makeshift headgasket at the roadside...
Looks like I'm in trouble with the Mrs's again... She asked me what I'd most like to do to her body... Apparently "Identify it" is not the correct answer!
Modifications: Drive a 2.2dti olympus, 2.8 lwb and 2.0i sport. Breaking... 2.4i and 2.3td 2.0i C20ne and x20se x 4 2.8tdi x2 2.2i A 2.2i B LWB x3 x22dth B dti lwb x3 y22dth B dti lwb x5 Call Fronty4x4spares on 01622 739908. Same day dispatch, next day delivery on 95% of items.
