Frontera Technical Support • View topic - Just had a Pre MOT ARRRRRRRRRRGGGGGGGG
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by RatCav on Tue Dec 20, 2011 3:46 pm
Someone at the front dropping the oil and changing stuff under the bonnet.
One person one side doing brakes, with another the other side doing welding.
One person in the back lifting carpet and trim for the inner arch modifications.
Then all move around.
Final touch Fogman in a pinny making tea and bacon sandwiches.
Must be easier than a 2.2DTi rear crank seal and repairing the actual crank while it is in situ.
It may be rainy so a large tarpualin would be useful. Would be a good wind break for the welder as well.
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Tue Dec 20, 2011 3:53 pm
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by andytats on Tue Dec 20, 2011 4:01 pm
If you were nearer i would of lent a hand. Hope it all go's to plain for you all.
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Tue Dec 20, 2011 4:34 pm
anyone coming got a spare 15" rim ? ive got a tyre for mick but he needs a rim to put it on, its only for a spare so dosent have to be anything fancy :wink:
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by justdan on Tue Dec 20, 2011 6:10 pm
iv got to chip in here gents and say EVERY 1 HELPING Robfog YOU ARE HEROS ..... i love FOG ............
a true owners forum :clap: :clap: :clap: :clap: :clap: :clap: :party: :party: :party:
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by Drift on Tue Dec 20, 2011 7:50 pm
Still have these calipers going cheap for you if needed Rob :wink:
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by Drift on Tue Dec 20, 2011 7:57 pm
Just be careful they dont warp or score the disc's :wink:
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by mickh on Tue Dec 20, 2011 8:20 pm
More troops on the way guys. If the weather is wet will throw the FOG field workshop (gazebo) in the motor for a bit of shelter. I have a patent pending steering box adjusting tool I will bring along that I used to shift a near solid adjuster on my last one, (ground down jemmy bar). Word of caution would be, don't take on too much at once, as we might end up with a truck in more trouble than when we started. Remember it gets dark about three o'clock. See you there for an early start. About 6 alright with you Fogman.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by RatCav on Tue Dec 20, 2011 9:27 pm
Just bought the air filter, oil filter, NGK twin electrode spark plugs, (and a new thermostat for the Trooper). Should of been £42, Halfords trade card £19.41. I love that card.
Between myself and Fudge we have enough steel to fabricate a new chassis if needs be.
I have the oil already.
I am sure we can sort out the gasket with what's in the garage.
I have a reel of copper/nickel brake line and flaring tools, with spare brake fluid.
Plan is to start at 9 am on the 28th. See folks at mine then. Coffee machine and kettle will be on. If Mrs RatCav is up for it cake might be available as well.
Is that everything covered?
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fudge on Tue Dec 20, 2011 9:53 pm
i now have a mig welder and 3sheets ofs steel
so looking all good so far
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Tue Dec 20, 2011 11:30 pm
ive just got to source a pinny & im good to go see you at 6 :crazy: i mean 9
if anyones got 2 metal plates 75mmx150mmx 12mm ish bring them along :wink:
its going top be like the a team da da da da, da da da :D
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by mickh on Wed Dec 21, 2011 10:05 am
Half inch thick plate Foggy? is that for the machine gun mounts.
mickh
Front winch.
CB radio.
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fudge on Wed Dec 21, 2011 10:09 am
All I can say is he is wanting to coppy mine
And since my new job I've been having fun :p :shh:
Ohh and we will need more MIG wire. And I'm not using the wire from work it will melt his body off it.
Need 0.8 mm gassless wire will havr a look for some later
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Wed Dec 21, 2011 3:58 pm
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fudge on Fri Dec 23, 2011 2:46 pm
well today i got my work gear,
and i have
mig welder,
steel
loads of tools
battrey nut runner
think i have everything i need
ohh and i got a big tent that isnt mine we can use as shelter :lol:
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by RatCav on Fri Dec 23, 2011 4:09 pm
I have a driveway, tools, brake fluid, brake line, oil, oil filter, air filter, new set of sparkplugs, kettle, tea, coffee, and bacon sandwiches.
oh and Fogman's pinny
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Fri Dec 23, 2011 4:34 pm
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Tue Dec 27, 2011 1:18 pm
i have a pot of copperslip incase needed, more tools, micks spare tyre & a slightly bigger bellie than i did last week :oh yer:
will you need the torque wrench ? ill bring it anyway :wink:
Re: Just had a Pre MOT ARRRRRRRRRRGGGGGGGG by fogman on Tue Dec 27, 2011 1:25 pm
theres no doubt rattys got some anyway but best to be on the safe side :wink:
