After a uv torch
Re: After a uv torch by alsavs on Fri Aug 26, 2011 8:00 pm
Hi Bigga the parcel arrived today :D. Just need to remove the bumper and find a dark place.
Need to repay you some how.
Alan
Alan.
alsavs
Registration Year: 1992/K
Modifications: Non as yet
Re: After a uv torch by Bigga on Sat Aug 27, 2011 7:06 am
no worries mate,just hope it dont cost you 2 much to fix it !
Bigga
Re: After a uv torch by alsavs on Sat Aug 27, 2011 12:48 pm
The dealership wanted 500 pounds plus to replace the condenser and dryer.We can get the parts our selfs for a hell of a lot cheaper than that.
Alan.
alsavs
Re: After a uv torch by Bigga on Sat Aug 27, 2011 12:58 pm
its easy enough to do,as long as system is empty.just make sure it gets pressure tested afterwards to make sure it all good,and when its put on vacuum the longer the better ! basically on vac it means that any moisture in system will boil away at something like 4 degrees !
Bigga
Re: After a uv torch by alsavs on Sat Aug 27, 2011 2:10 pm
Cheers for that i think we might be able to use a bit of kit think its known as a AC690.Think you can adjust the vac time on this model.
Alan.
alsavs
Users browsing this forum: No registered users and 44 guests
