Frontera Technical Support • View topic - Just been offered a 2.0ltr ..
Re: Just been offered a 2.0ltr .. by PaulHooligan on Fri Jul 22, 2011 7:55 pm
PaulHooligan
Skype Username: paul-hutson
Re: Just been offered a 2.0ltr .. by BoxCleva on Fri Jul 22, 2011 7:57 pm
I wouldn't stress , it's far more likely to be a simple wiring fix or the relay.
Re: Just been offered a 2.0ltr .. by andysd1 on Fri Jul 22, 2011 8:18 pm
or the plug has come of the top of the pump,
Re: Just been offered a 2.0ltr .. by PaulHooligan on Sat Jul 23, 2011 4:41 pm
Well i've bought it and christened it "FUGLY" . Suppose I had best buy a socket set and some spanners now
Proper question..... will my spare set of 16" trispoke alloys fit on it without looking stupid or causing issues?
PaulHooligan
Re: Just been offered a 2.0ltr .. by steveM on Sat Jul 23, 2011 4:58 pm
'bout bliddy time too!!! :lol: :lol: :lol:
ps looks are down to the individual, don't think you'll have a prob fitting them though..
steveM
Modifications: 2.0 Sport Transglobe.
Inherited K&N filter
R/diff sorted
31x10.5 15's
August jobs:
+4" suspension,
Fuel pipes, s/s straps, recon the guard,
Service
Re: Just been offered a 2.0ltr .. by Wilberforce on Sat Jul 23, 2011 5:27 pm
Nae bad for the price...
Your spare 16's will go on, although will probably sit well inside the arches what with it being a leafer. Good luck with the project though mate.
Re: Just been offered a 2.0ltr .. by PaulHooligan on Sat Jul 23, 2011 5:33 pm
PaulHooligan
Re: Just been offered a 2.0ltr .. by Loneranger on Sun Jul 24, 2011 9:34 pm
Did i hear my name mentioned ???
I had a similar problem with mine (not the newer one) we pulled two pipes of turned it over a fuel started to pump through, jobs a good un.
Having stripped a tank recently Paul i can do that bit for you, testing relays i guess with a haynes manual we maybe able to muddle through.
Send me a pm if you want a hand one evening, working next weekend and probably most of it.
Happy to give you a hand but be warned "i am a learner on these things"
Cheers Pete
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
Re: Just been offered a 2.0ltr .. by PaulHooligan on Sun Jul 24, 2011 10:05 pm
Good old boy cheers for that :D
PaulHooligan
Re: Just been offered a 2.0ltr .. by Loneranger on Sun Jul 24, 2011 10:13 pm
Failing that Paul i know a great mechanic who lives in Stoke Bruerne not a millions miles away, so if all else fails i can give you his number.
Pete
Loneranger
33" KL71 mud tyres
winch
Re: Just been offered a 2.0ltr .. by N1ova on Mon Jul 25, 2011 1:00 pm
Any luck getting it running???
N1ova
Vehicle Name: Blue flash
Re: Just been offered a 2.0ltr .. by PaulHooligan on Mon Jul 25, 2011 3:04 pm
Havent looked yet ended up working the door all weekend on a shitehole bar in Leighton Buzzard such joy, will get on to it shortly . Will probably take the relay out of Dave and try it in Fugly if that does not present an issue with Dave.
Then if that fails drop the tank and swear lots :D
PaulHooligan
Re: Just been offered a 2.0ltr .. by James Bass on Mon Jul 25, 2011 3:35 pm
Fugly will have the earlier C20NE engine whereas Dave has the X20XE engine. Best check the relays are the same first. :wink:
Re: Just been offered a 2.0ltr .. by PaulHooligan on Mon Jul 25, 2011 5:02 pm
Good point...See told you I was dense!
PaulHooligan
Re: Just been offered a 2.0ltr .. by PaulHooligan on Fri Aug 05, 2011 4:26 pm
Dunno if I can be arsed to fix Fugly so is there much interest in breaking it?
Please bear in mind though I dont want to be left with a hoodless wreck on my drive so the wheels will be last to go !!!!
I know what it owes me and the plans to turn it on to a pick up have had to be put on hold had my work hours cut so its an expense I cant afford.
So make me an offer for the thing as it is or for bits. If you want/need anything heavy you got to come collect it cos I aint got the kit to lift it :D :D
New clutch in May
11 months MOT
Bit tatty needs a good clean
and it dont start because the fuel dont get from the tank to the engine bit
PaulHooligan
Re: Just been offered a 2.0ltr .. by Drift on Fri Aug 05, 2011 4:40 pm
If your braking a car could you post in Frontera Parts for sale section please, just saves this thread going off topic and getting locked.
Ta 8)
Re: Just been offered a 2.0ltr .. by PaulHooligan on Fri Aug 05, 2011 4:52 pm
PaulHooligan
Re: Just been offered a 2.0ltr .. by PaulHooligan on Sat Aug 06, 2011 12:41 pm
Update ....
Just been out and had a proper look over it. Its filthy and smells (bloody smokers) but its only got 89k on the clock and seems solid enough so have got another dose of optimism that I can fix it :D :D Wont last tho im sure !!
PaulHooligan
Re: Just been offered a 2.0ltr .. by 4x4 bobby on Sat Aug 06, 2011 1:49 pm
Get it sorted Paul you know it makes sence!!!
Re: Just been offered a 2.0ltr .. by BoxCleva on Sat Aug 06, 2011 2:17 pm
Start a new thread in the 2.0 section Paul. I'm sure it won't be as bad as you think.
Users browsing this forum: No registered users and 44 guests
