Frontera Technical Support • View topic - 109p ltr for bio
109p ltr for bio
Re: 109p ltr for bio by yaki on Sat Jun 11, 2011 10:27 pm
Longer term I am going to get the diesel pump on the 2.8 rebuilt when I do the engine, been speaking to Diesel Bob and they can do a full pump rebuild, tweak it for more power and fit new type seals for approx £225-
Re: 109p ltr for bio by Drift on Sat Jun 11, 2011 10:55 pm
Chris, it may be worth getting the injectors recalibrated at the same time :wink:
I know WVO and Bio give slightly less MPG than DERV.
WVO seems to be available commercially at around 70p per litre but then you have the cost of 50, 20 and 10 micron filters and a few barrels for a very basic set up plus an inline heater for winter minimum.
With the cost of extra fuel filters and the alterations, I might stick to DERV as its not doing enough miles to warrant it :(
Wish the HDI could cope though :twisted:
Re: 109p ltr for bio by yaki on Sat Jun 11, 2011 11:12 pm
Re: 109p ltr for bio by Drift on Sat Jun 11, 2011 11:18 pm
I have a set here you could borrow and replace if any good (question mark doesnt work on this crappy heap :lol: )
Re: 109p ltr for bio by yaki on Sat Jun 11, 2011 11:26 pm
Thanks for the offer, have a complete engine under a tarp so will be pinching them off that
Re: 109p ltr for bio by Drift on Sat Jun 11, 2011 11:34 pm
No probs, hey Chris, do me a favour and pop a picture of your injectors in this thread please mate when you pull them.
viewtopic.php?f=21&t=42357
Seems my spares could be a set of 3.1 and 2.8 but not sure which is what :wink:
Ta
Re: 109p ltr for bio by yaki on Sun Jun 12, 2011 12:52 am
No worries, will do
Re: 109p ltr for bio by Drift on Sun Jun 12, 2011 12:55 am
Cheers bud 8)
Re: 109p ltr for bio by ARMYOF1 on Mon Jun 13, 2011 1:26 am
Have a look at this....
Field Remedy: 1707
Subject: Diesel Fuel - Contains up to 7% Bio Diesel (FAME)
Models: Engines: Option:
All Other (See options) DIesel
Complaint: Since January 2009 some oil companies mix up their Diesel fuel with up to 7% of Bio fuel (FAME = Fatty Acid Methyl Esters) like RME (Rape Oil-Methylal-Ester).
Cause:
Production:
Remedy:
This is in accordance with the valid DIN EN 590 and does not harm the
fuel/injection system.
Please note: Diesel fuel mixed up with 7% FAME according to DIN EN 590
must not be mixed up with 100% Bio Diesel which is not allowed to be
used in Opel engines.
FunctionalGroup: J - Engine
Complaint Group:
Trouble Code:
ARMYOF1
Model: 2.0i Sport Niagra 3dr
Re: 109p ltr for bio by drinksoptional on Mon Jun 13, 2011 2:03 am
Whats that
Re: 109p ltr for bio by Drift on Mon Jun 13, 2011 10:44 am
All fuel in the uk must contain five percent bio fuel at least by legislation. It's rape seed oil thT is usually used.
Re: 109p ltr for bio by drinksoptional on Mon Jun 13, 2011 2:19 pm
Gotcha.
The lwb has been sitting since i last ran it. This morning i started it up. first turn started n died second trun fired up little smokey which it has never been but reckon that was just the fuel from first go. Was bit rough for first few seconds i just increased the revs which i do not like doing on any engine i prefer to let them warm up a bit first before applying power to let oil get going.
I drove it 1 mile to super market then drove home was running fine.
It will run on 100% bio on the first run i saved nothing due to needing new filter. I will continue to run whats in the tank before i decide the long term i dont know
Re: 109p ltr for bio by drinksoptional on Wed Jun 15, 2011 12:19 am
117 miles on bio
Re: 109p ltr for bio by drinksoptional on Mon Aug 22, 2011 4:56 pm
i managed 200 miles on veg/diesel mix. i have now put 18ltrs of bio diesel in the tank today.
side effects only one rough idle from cold start apart from that runs great better mpg aswell
Re: 109p ltr for bio by justdan on Mon Aug 22, 2011 5:01 pm
i run my old r reg terrano on veg oil out of tesco lol :dance:
she ran finme on it , it was never 100% tho ..... tented to keep it at 50/50 ........
justdan
Vehicle Name: Paddy
Alpine I.C.E system
Combra shiney nudge bar
Irmischer wheels
Re: 109p ltr for bio by drinksoptional on Mon Aug 22, 2011 5:22 pm
i was in aldi today going oooh veg oil £1.19 a litr .
i will try run it on 100% bio till winter if i can
Re: 109p ltr for bio by drinksoptional on Thu Aug 25, 2011 10:39 pm
Well thats 38 litres of bio used and i had to add 9 liters of diesel as i had run out on motorway light was on but i ran it till it was empty again before filling up so sort of counts
Re: 109p ltr for bio by gregster on Thu Aug 25, 2011 10:43 pm
I hope your profile is wrong and are putting this in a derv truck....cos the 2.0i in your profile aint gonna like it :wink:
Re: 109p ltr for bio by drinksoptional on Thu Aug 25, 2011 10:50 pm
ha ha aye its in the lwb 2.5 td icnat have two in my profile can i hmm
Re: 109p ltr for bio by gregster on Thu Aug 25, 2011 10:52 pm
I got 8 in mine... :oops:
