[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - 4x4 Snow Ice Mud Escaper Tyre Traction Tracks
Bit of 6mm bar with a plate weded on it. Weld a bump stop behind it to stop it from opening more than 90degrees. Remember 6mm fillet weld 1 inch long will hold a ton. These things are going to have to be around 10" wide for most tyres out there.
Could each part of a waffle board be a seperate section with an angle on each edge if needed that join together using a dovetail joint to stop them from slipping apart if the wheels spin just an idea.
Thats fine on a flat surface but it could be a problem on uneven surfaces, also it could split apart and fire from under the wheel like a missile when the wheel spins.
