[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - shaking
Modifications: Maxxis Trepador muddies on a series off-set rims. 2" suspention lift. removed side steps. uprated recovery points. silly stickers and loads of other bits.
Could be a few things but likely to be the prop stretched to far with the lift and needs a spacer and may not ne seating correctly at the gearbox input, there maybe a slight leak in that area. Or loose body mounts could offer the same symptoms.
