[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Unbelievable, its a miracle
There doesnt seem to be a bad review on this stuff, so I ordered a can to give it a try on A, if its good then I may get another can for B when she's rebuilt.
Modifications: ~Work to date~ New front disc's and pads New rear shoes New air filter New fuel filter New rocker gasket New Exhaust AVM Hubs General Grabbers
If anyone else buys this stuff click on the group button first, there is a voucher code that give another 10% off... I only fond that AFTER I had bough some
Done a hundred miles now and I'm not sure there is any difference to be honest. It may be a little more eager top end but that may be me 'wishing' it to work. The truck has also developed an odd fault that it just cuts out, but only very occasionally , no idea if it's related or not , we'll have to see.
Only done about 50 mile but not sure if it is a tad more responsive or if it's my imagination so will let you know when I have done a few more miles but I think it is
Ok, I've done 350 miles now and can honestly say I haven't noticed any difference. That's not to say that it hasn't done some good, but nothing that has shown itself in the way the vehicle performs.
i put some in the wifes car(petrol) and my mate put some in his pajero(diesel) and both made no difference at all,was thinking of putting some in mine but i think i will just sit on the fence for a while
I've done about 150 miles now and it has made a difference. While mine was at idle it has a slight rough idle sits and idles fine just slighly lumpy hard to describe, I put it down to the EGR valve but since using this it now sits and idles as smooth as you like so I recon it has been the egr valve just been suited up a bit
