Frontera Technical Support • View topic - vortex generator
vortex generator
Re: vortex generator by jason on Thu Jan 21, 2010 9:49 pm
Re: vortex generator by Drift on Thu Jan 21, 2010 10:02 pm
Re: vortex generator by jason on Thu Jan 21, 2010 10:12 pm
The only problem i had when after fitting it the ECU light came on :?: :?:
But when every think was back it was ok :shock:
Re: vortex generator by Drift on Thu Jan 21, 2010 10:17 pm
I never had that problem, you must have disturbed the MAF or had a leak?
Re: vortex generator by Drift on Thu Jan 21, 2010 10:18 pm
Ahha, mine was a 20l, just spotted yours is a 2.2, still think it will be MAF related though.
Re: vortex generator by Road Hog on Thu Jan 21, 2010 10:21 pm
Re: vortex generator by jason on Thu Jan 21, 2010 10:24 pm
Re: vortex generator by Road Hog on Thu Jan 21, 2010 10:28 pm
Mass Air Flow sensor :wink:
Re: vortex generator by jason on Thu Jan 21, 2010 10:42 pm
Re: vortex generator by Frenchfarmer on Thu Jan 21, 2010 10:57 pm
Frenchfarmer
It works!!!!
Re: vortex generator by jason on Thu Jan 21, 2010 11:00 pm
Re: vortex generator by Drift on Thu Jan 21, 2010 11:04 pm
There is an oval shaped grommet in the firewall/bulkhead its likely its missing or not seated correctly and leaked through there :wink:
Or the water has come up through the gear stick gaiter and leaked into the footwell.
Re: vortex generator by jason on Thu Jan 21, 2010 11:17 pm
Re: vortex generator by domino on Thu Jan 21, 2010 11:41 pm
The problem with 'induction kits' on these engines (in the Astra's anyway) is that they run quite hot.. so you're raising the temperature of the air entering the engine which can make it run a bit... crapper :)
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: vortex generator by Drift on Thu Jan 21, 2010 11:54 pm
As domino said you do need a good cold air feed.
Sounds like the water has entered the grill below the windscreen and your vent was set to open...whoops :lol:
Re: vortex generator by Frontycustoms on Fri Jan 22, 2010 1:26 am
The grill below the window :? Ya mean the scuttle panel then Ste :lol:
Re: vortex generator by audiman on Fri Jan 22, 2010 6:47 am
well i got to thinking if i got a secondhand K&N induction kit
could i convert the airbox it so that it fits inside the airbox and drill lots of holes in the lid to allow more airflow
this way i could leave the snorkel on and hopefully the K&N will suck in more air
would it work?
Lee :)
ps vortex will be removed today
clueless about modding but learning
audiman
Vehicle Name: Elma Fud
Modifications: 2"suspension lift calmini shackles on rear bilstein extended shocks on back and Procomp shocks on front
Bullbar roof mounted spots front and rear and spots on bulbar chrome dished alloy with Kumho 31's muds
Homemade snorkel,Fiesta cobra bucket seats,recovery shackles front and rear,Led bulbs in all lights,rear tail lights off a rodeo, reverse gear warning buzzer,K&N panel filter,rear aerial mount off spare wheel carrier,cb with extra speaker and radio mike,Milner rear springs
Re: vortex generator by Drift on Fri Jan 22, 2010 8:06 am
Point less having a cone filter and a snorkel if you do that plus the airbox needs to be airtight, you can get a k&n panel filter and fit that into the airbox then seal the airbox up with sealant and use a snorkel, thats the way to go snorkel wise.
Re: vortex generator by 4x4 bobby on Fri Jan 22, 2010 8:17 am
Re: vortex generator by audiman on Fri Jan 22, 2010 10:13 am
well i don't drive the truck every day so its been standing since wednesday night got in it this morning and it ran like a total pig so i realised that when the vortex was fitted engine was warm but was stone cold this morning so took airintake pipe off and have removed the vortex and will refit the pipe when i go home looked at airbox and my idea wold not work so think the panel filter will be the way to go
well i have learnt the hard way
Lee :)
audiman
