Confirmation needed ...
Re: Confirmation needed ... by alex on Thu May 21, 2009 8:39 pm
Bobby in the bath.... Not my idea of a pleasant thought for a Thursday night. Driven me to drink. Watch the rubber duckies.
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 8:45 pm
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 9:18 pm
Thanks Bernie, but as I said it is a new sensor already, and it hasn't made any difference to the problem - this is why I wanted to check to see if the light should come on when disconnected, as if it should, then I think the problem is in the loom itself - hence why changing the sensor made no difference - if that makes any sense! :lol:
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 9:41 pm
Ahhhhh sorry missed that one :oops: :oh yer: I see your reasoning & cannot fault it :D
How many wires & what colours have you ??
Re: Confirmation needed ... by Alchamist on Thu May 21, 2009 9:45 pm
Three, and unknown at the moment - can't see in the dark. Will have a look tomorrow ;)
Jay
Alchamist
Modifications: .
* CB
Re: Confirmation needed ... by Road Hog on Thu May 21, 2009 9:59 pm
That will be.......
Black ........ reference signal out
Grey ........ Nuetral
White ...... Heater
If you want to test the sensor,take it off car & clamp in a vice,connect a multimeter (set to 0 - 5 volts range)across black + & Grey -,heat the element with a blowlamp as the element caseing comes to red heat it should have a reading approx 1volt,now play the flame off & on the voltage reading should fluctuate accordingly.
If that wiring section works the fault must be deeper in the loom :wink:
Re: Confirmation needed ... by Sir-Doris on Fri May 22, 2009 12:23 am
Only slightly relevant but on the 2.2 the EML come on when the Lambda sensor is unplugged.
Re: Confirmation needed ... by Frontycustoms on Fri May 22, 2009 12:31 am
Jay, diss the plug on the ecu n bell out the cables across each other. If no continuity across any of them then I would go for an ecu fault. Rob Fudsters off his truck n see if it makes any difference maybe. Just a thought, but its how we find shorts in my job. :wink:
Re: Confirmation needed ... by Road Hog on Fri May 22, 2009 1:02 am
That works on the assumption that the sensors etc are normally closed,unfortunately the Lambda is normally open on a cold engine therefore no continuity is correct.
Re: Confirmation needed ... by Frontycustoms on Fri May 22, 2009 1:04 am
But it would test the cables in the loom though Bernie :wink:
Re: Confirmation needed ... by Sir-Doris on Fri May 22, 2009 1:06 am
Have a look here for Lambda diagnosis: Clicky Linky
Re: Confirmation needed ... by Road Hog on Fri May 22, 2009 1:09 am
End to end indeed it would Mark,I read your post as testing across the terminals within the connector :oops: :oops: must be getting tired off to bed now before I mess up properly :wink:
Re: Confirmation needed ... by Frontycustoms on Fri May 22, 2009 1:11 am
LOL.....u old ens need ya sleep eh Bernie :lol: :lol: :lol: :butt: :axe:
Re: Confirmation needed ... by Road Hog on Fri May 22, 2009 1:18 am
you young whippersnappers will catch me up one day :butt: night night chaps
Re: Confirmation needed ... by meooo on Fri May 22, 2009 8:33 am
If your Lamda sensor is reading constantly Lean, I would suggest you have a missfire, causing the sensor to see too rich a fuel mixture and constantly trying to weaken it off (which it cant do due to the missfire)
meooo
Cookie monster
Cookie monster
Vehicle Name: dead
Still sporting Salisbury mud
Gone to meet its maker :(
Skype Username: john.hird8
