Frontera Technical Support • View topic - Welding a fuel tank
Welding a fuel tank
Re: Welding a fuel tank by Drift on Fri Mar 27, 2009 11:31 pm
Re: Welding a fuel tank by damrabbit on Sat Mar 28, 2009 2:48 pm
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: Welding a fuel tank by Trugga on Sat Mar 28, 2009 7:31 pm
Job done :D
Tank guard came off no problem - 8 bolts
Inspection plate (inside) - 4 bolts - disconnected electrics and pipes
Tank came away ok - 6 screws and 4 bolts.
Disconnected filler and breather and away from the truck it came.
It is in a sorry state and will need replacing. Even so, being steel, Weave was up for the challenge.
Even though I believed the tank to be near empty, we still managed to get 20l out of it
filled it with water via a hose and let it run through
Dave welded up two pin holes on the underside, but not before Postfinder tried to set fire to it.
Went back together rather easily, despite dodging the rain and hail showers, and was filled up with 35L of fuel. Started first time and ran without hesitation... until a couple of mile down the road when it stuttered a bit as I guess some water got into the pipes.
Got home and at idle heard the pump whining, so popped down the road to fill up (£30) - pump has stopped whining.
An excellent bit of Black Country bodging.
Cheers chaps
Re: Welding a fuel tank by Drift on Sat Mar 28, 2009 7:36 pm
Great stuff :clap: :clap:
Re: Welding a fuel tank by alex on Sat Mar 28, 2009 8:15 pm
:dance: :dance: :dance:
Well done boys.
Re: Welding a fuel tank by john (smifffy) on Sat Mar 28, 2009 8:18 pm
well done at least there was no Image
Re: Welding a fuel tank by Postfinder on Sat Mar 28, 2009 8:24 pm
Postfinder
Modifications: The biggest hazard to my truck is Me.
"there is nothing wrong with getting a Sport airborne, bad things only happen when you land"!!
Re: Welding a fuel tank by weave67 on Sat Mar 28, 2009 8:26 pm
yes it was a controlled explosion :D i didnt see it though,i looked myself in the downstairs toilet :roll:
