[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Where does your fronty spend most of its time?
Not yet glad I still had it would have been in the s**t last week without it. It is still for sale I have droped the price to 750 quid ono as it needs a mot it should pass if it is still here I might be at Balla in May
Sounds like a tractor But goes like a rocket - Poor mans auto parts.
It would be no.3 for mine at the moment.It did have an off day recently though, just didn't seem to pull as well as normal but was better the next day and seems to be ok now.Changed the oil and got sold a different type to the normal and its better than the usual stuff the engines much quieter so will get the same again next time.Happy.
Modifications: 2.5 lwb dark green with a two inch bodylift.Steel lockers over wheel arches to store stuff in. 2.3 blue.new leaf springs.changed drop down tailgate with rear swing door to take spare wheel.now not on the road awaiting repairs.
