Re: WHAT YOU DID TO YOUR TRUCK TODAY! by weave67 on Sat Jan 31, 2009 11:13 pm
well ime kind of glad i aint been messing with trusty rusty today ,its giving the cuts and grazes that i got last weekend time to heal up :roll:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by MuddyFairy on Sun Feb 01, 2009 8:49 am
Changed Diff Oil, bought rear pinion seal, Towed another Fronty from Crewe home. It's looking like a car yard here now!
MuddyFairy
Vehicle Name: Mini Monty
Modifications: 2.2 1998 S Reg LWB in dark metallic green, needs engine. RIP
2.4i 1994 M Reg LWB Carabic Blue, Replaced suspension all around. Planned suspension lift, CB, winch etc. When time and money allows. SOLD
Planning on getting a shorty when money allows!
2.0 1998 R reg SWB (Finally!)
Skype Username: Rachael_Edwards1
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Sun Feb 01, 2009 11:29 am
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by brachunky on Sun Feb 01, 2009 11:50 am
Need to brave the freezing cold to solder a bunch of wires I cut thru with the angle grinder :lol: :lol:
3 inch suspension lift
31 10.5 Muds
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sun Feb 01, 2009 1:45 pm
:oh yer: Nice one Mart. bin there done that.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by john boy on Sun Feb 01, 2009 3:09 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by brachunky on Sun Feb 01, 2009 3:14 pm
Thanks chaps :lol: Glad im not alone in making daft mistakes :wink: Alls working good again!
31 10.5 Muds
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dandan on Sun Feb 01, 2009 4:08 pm
The best one is when you forget to check when welding :wink:
If you're sat there thinking things just can't get any worse, just wait......
dandan
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Rich on Sun Feb 01, 2009 5:46 pm
i had got my frontera up an axle stands today with the front driver side wheel off i was checking the bolt around the gearbox after changing the clutch i thought why iam under the car i will check the bolts on the prop i put the spanners on the first bolt gave them a good hard pull and the car slipped forward about an inch on the axle stands ive never moved so fast to get from under the car
i thought fook that i put the wheel back in and came in had a stiff drink and then another
lesson to be learnt even on axle stands your car can still slip be careful
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by bobbinsjob on Sun Feb 01, 2009 7:02 pm
tried to fit my new A bar today but the bracket needs fettling because of the body lift :roll: :evil:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by phil acko on Sun Feb 01, 2009 7:30 pm
i put some oil in her pumped the slowy up in her an changed the fuel filter i soaked with wd40 3 weeks ago
oh an took me rott 4 a walk :dance: :D :lol: :drink:
oh an we watched the match 2 gether lol
phil acko
phil acko
Modifications: nil yet oh k+n lol
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sun Feb 01, 2009 8:16 pm
When I put the new tyres on my SWB Dave was with me. It started to shift backwards with a wheel off :oops: Luckily one of us held it while the other slipped the wheel back on :roll:
Cant remember who did what, but we did it quick like :D
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by jellybaby on Sun Feb 01, 2009 8:22 pm
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by dandan on Sun Feb 01, 2009 8:23 pm
Well I stared at "my" Frontera on ebay. Why can't it be the 24th already so I can get this medical out the way and know exactly where I stand
dandan
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Retro Pedro on Sun Feb 01, 2009 8:35 pm
Frooze me gonads off trying to fix the bloody thing. Nearly got there before I gave in to the cold wind.
Whilst I had the rad and intercooler out, I decided to sort out the surfice rust on the chassis parts that I could reach.
Done that yesterday by scrapping and wire brushing, then repeated coats of gel before giving it a coat of Hammerite black paint which is also supposed to attack any rust.
Then today, finished off replacing power steering pipes and steering box, put new alternator and steering pump belts and reassembled the radiator fixings. Only the front and horn brackets to put back on. Put in the new transmission fluid for the power steering and anti-freeze mix coolant and hope it starts.
Bit of a shame really because we have got a covering of snow, apparently with more to follow overnight.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by alex on Sun Feb 01, 2009 9:10 pm
Yep, thats the story, memory of a an OAP me :oops: Was fun. Got them tyres in the back of the shorty any time you want.
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Drift on Sun Feb 01, 2009 9:40 pm
I lost a clear headlight cover at Bala off road ( so lashed the other :lol: ) and unfroze mine and Andysd1's manual hubs, they where stuck locked and in blocks of ice after descending the Wayfarer :shock:
Thought we might have to pee on them to warm them up but deicer and pliers sorted it :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by Frontycustoms on Sun Feb 01, 2009 11:54 pm
Well after i cleaned my van out i got onto sortin the snorkle out.............nearly there now :lol: :lol: :lol:
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by boybilbo81 on Mon Feb 02, 2009 12:06 am
I was outside in the snow wiring up my work lamp, and fabracating a switch plate for future Spots, Strobes and rear lamp. Dam it was cold. Just goes to show how many of us will go out in the coldest of weathers to be with our loved ones and leave the missus indoors, was cold but peacefull.
Image Image
boybilbo81
Modifications: C75 Aluminium Expedition Roof Rack
Front Roof Lights
Rear Work Lamp
Roof Strobes front and rear
Bonnet deflector
2x 18mm Galvanised bow shackles on the front
Insa Turbo Traction Track Tyres
235/70/16
2x CB Radios
PA System
Planning:
2" Body Lift
2" Suspention Lift
Moddified Air intake (not Snorkel)
Re: WHAT YOU DID TO YOUR TRUCK TODAY! by furball on Tue Feb 03, 2009 12:37 am
OK, so by the standards of folks on here it's not exactly technically challenging, but bearing in mind I have never ever done anything mechanical in my life, yesterday I replaced the radiator in my car all by myself (with help and pointers from AndySD1) :dance:
I might even have a go at servicing it next :D
furball
